Author Topic: Kailh box brown VS Gateron brown?  (Read 14153 times)
Offline Pavilions
« on: Tue, 24 July 2018, 11:31:20 »
Is there any difference between the tactility and the weight of these switches? If you tried them both which one you prefer?
Offline oumakavoula
Re: Kailh box brown VS Gateron brown?
« Reply #1 on: Tue, 24 July 2018, 13:20:15 »
I've tried khail box brown and the tactility is very lackluster
Offline Pavilions
« Reply #2 on: Tue, 24 July 2018, 17:49:49 »
so do you advise me to keep using the Gateron browns?
Offline oumakavoula
« Reply #3 on: Wed, 25 July 2018, 01:20:38 »
you can get a switch tester from kbdfans for quite cheap and you will be able to tell for yourself and try the other khail box variants. I've never tested gateron brown so I don't want to mislead you.
Edit : I should add that i've ordered a switch tester like this and after using it for 1~2 months the khail box brown and khail box burnt orange now have now a slight clicky sound to them.
« Last Edit: Wed, 25 July 2018, 01:25:30 by oumakavoula »
Offline nogoodnames444
  • I like keyboards
« Reply #4 on: Wed, 25 July 2018, 13:14:08 »
I have a box brown on a keyswitch tester than is clicking on the upstroke
« Reply #5 on: Wed, 25 July 2018, 22:10:01 »
Given the recent  clicky-sound gate on the box switches..
We aught to hold off until precise cause is found
« Reply #6 on: Wed, 25 July 2018, 22:12:28 »
Don't forget the keycap cracking.
