Author Topic: Advanced Electronics Builder - New To Keyboards - Looking For Some Direction  (Read 2983 times)
Offline evancorylevine
Good morning!
Like I said, I'm an advanced electronics builder (I build a lot of audio electronics: synthesizers, guitar pedals, amps) and I'm looking to make myself a keyboard or two.
I would really like a split keyboard that's backlit. What I need to know is how to do this cheaply.
I can do all kinds of soldering, including SMT. I just need a solid (decently documented) design, a BOM, and some sources for parts.
What do you all think?
e!
--Ergodox Infinity--
Hahahah well... of course that's what seemed the most exciting in my searches. I haven't been able to find a simple BOM and parts sources, though, yet.
Is there documentation on how to build one cheaply somewhere? All I'm seeing is very expensive options.
okay. now that I'm looking at ergodox.io I'm seeing that everything is really laid out for me. Where can I source my parts most cheaply? I'm used to Mouser, Newark, etc, but not the keyboard specific parts
Is there a mouser cart I can grab somewhere before I start making one?
https://geekhack.org/index.php?topic=95196.msg2593996.0
That looks awesome! Now how do I get the parts/build one!?
Probably have to contact the person who ran the group buy and ask about extras or try and find someone selling theirs.
Offline hineybush
  • student of error
    • hineybush keyboards
You could piece your own kit together if you wanted. Do you do PCB design? If so you could do it the "hard way" and start from the ground up.
QMK (firmware) is pretty good for split boards, and supports underglow/backlight. The learning curve isn't horrible if you have experience with coding and flashing. As far as parts go, if you design your own PCB you can obviously generate your own BOM with the packages/specs you decide on. Others have published their designs/BOMs/etc on github in some instances, but I can't get you any direct links for those atm. There's a few PCB tutorials around 1 and 2 that can get you off on the right foot.
Discord servers are a good place to ask questions too, the "official" r/mk one (most active users iirc) is pretty good for low/mid level questions (you can PM me on there if you'd like, I'm @hineybush#0069). There's many experienced PCB designers there including myself who don't have issues with helping out.
As far as going from the Ergodox link, Mouser/Digikey are good. For bulk components like resistors, caps, etc check out LCSC.
Dactyl is the most exciting board right now IMHO.
Overall, I'm not yet convinced such a deep bowl shape is good for tented orientation.
It's exciting because you can go in and edit that to whatever concave / position you want.
Ergodox is mostly fleshed out.. the Thumb cluster is of contention,
Mostly a NON-Issue (My experience as a long term ErgoXclusive user),
The fight over the thumb cluster has been overblown by bad-typists with bad habits, who have an unwillingness to learn some new moves.. hahahaha
-- But, I have to mention it-- because if someone isn't very coordinated/ or have lesser hand-dexterity in general..  changing/ adopting new typing habits may be cumbersome.
This is the best budget option
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.78cd3e76Pjrx4y&id=526316023548&_u=h2vv737kd3d4
Offline ag36
I recommend ergodox ez because infinity is a bit hard to get.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Bigaku
  • コンニチハワタシノナマエハビガクデス Hello my name is Bigaku or ビガク
HHKB Pro 2 With GMK Space Cadet
Colorways I'm supporting
Some info that was missing: ErgoDox is an open design with parts from different companies. ErgoDox EZ is a brand of ready-made ErgoDoxen.
Input.Club's ErgoDox Infinity has the same layout as ErgoDox but is not compatible with the original design.
ErgoDox Infinity has backlighting but the original ErgoDox design does not.
There is a schema somewhere with added backlighting to the original ErgoDox but I have not seen it built.
