Author Topic: Any Gekhakr with Wound-Care Xperience ?  (Read 2708 times)
« on: Mon, 30 July 2018, 08:44:56 »
Right'o
It's been 36 hours since the Incident:
Glass meets finger, cleanly cut off ellipse discus shape
Major axis 9mm, Minor axis 6mm, 2.5mm thick in middle.
Lot's of blood
201016-0
Had Gauze on the wound,
Gauze is stuck
Attempted to Saline-Soak it off for 30 minutes, still Not coming off.
I cut around the gauze that isn't stuck, so only a piece which is approximately the size of the wound itself is stuck.
If I pry at it, it seems to bleed. Sooooooo,,, googled, not definitive.
Could I just put some alcohol on it annnd then some neosporin, then bandage around it ?
Does it HAVE to come off any time soon, or is it like a splinter, and u could leave it there w/out much consequence. ??
Re: Any Gekhakr with Wound-Care Xperience ?
« Reply #1 on: Mon, 30 July 2018, 09:00:05 »
I would avoid putting alcohol on it.
Offline JianYang
« Reply #2 on: Mon, 30 July 2018, 09:59:27 »
Superglue it and move on.
Alternatively douse it in alcohol and set it alight - that should take care of the gauze  :D
But in all honesty, I have had some deep cuts, usually try to seal it with superglue. Try not to get it into the wound, but to seal the outer layer of skin. If it gets into the wound, it delays heeling time. This is a real challenge sometimes when you only have one hand left to work with (because you are working on the other).
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Mon, 30 July 2018, 12:15:04 »
HOSPITAL
« Reply #4 on: Mon, 30 July 2018, 14:31:07 »
Gauze is stuck
Not good. In an ideal situation the fabric will be incorporated in the scab and shed with it in a few days, but there remains a possibility that it is an infection trap. If you are not willing to rip it out or get professional help, try to keep it as clean as possible and re-apply ointment regularly.
- Oliver Willis 2026-08-01
  • Live long and prosper
« Reply #5 on: Tue, 31 July 2018, 11:59:10 »
amputation
tp thread is tp thread
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Tue, 31 July 2018, 13:22:27 »
amputation
Yes, that's also what I always prescribe when someone in my lab gets hurt. In any way.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Tue, 31 July 2018, 13:30:05 »
Sounds like a plan
