Author Topic: Alps housing broke....help  (Read 1770 times)
Offline keimura
« on: Wed, 15 August 2018, 11:23:46 »
I was taking the caps off from a focus FK-2001 when the stem broke through the housing while still on the cap...
I was trying to pull straight up like I've seen people recommend before but did I do something wrong or does this happen from time to time?
Also, what's the best way to fix this?
Super Ggue
buying a loose switch and take the housing
3d print a new housing
duct tape..?
Offline keimura
Re: Alps housing broke....help
« Reply #2 on: Wed, 15 August 2018, 16:04:46 »
...ok i'll look for a loose switch on ebay.
Thanks for the quick reply!
Offline method_
« Reply #3 on: Thu, 16 August 2018, 07:44:56 »
Oh snap  :(
thock program.
