Author Topic: dark theme?  (Read 3593 times)
Offline vanderzee
dark theme?
« on: Sun, 16 September 2018, 07:06:58 »
how do i switch to the geekhack dark theme?
when im logged off the backgroud is black with red and orange letters, when i log in the background is white and black letters
thanks a lot
Offline Aerizu
  • Professional Lurker
Re: dark theme?
« Reply #1 on: Sun, 16 September 2018, 07:13:32 »
1. Click "Profile".
2. Go to "Modify Profile" -> "Look and Layout".
3. Change "Current Theme".
 :thumb:
Re: dark theme?
« Reply #2 on: Sun, 16 September 2018, 07:22:51 »
Tp4 uses dat  Firefox 47 + Color Toggle.
Everything on the internet looks like This..
Grey font on Black Background.
Monitor is probe-calibrated for 62cd/m^2 white luminance.
62 is the max you want for a dark room w/ single 40watt lamp behind monitor.
40-45 cd is the max you want for total darkness, (most monitors doesn't go down to 40 in settings, must use software limiter, which probably will reduce contrast ratio, making the image quality worse.)
Foreground (font) color #454545
Background color #000000
If you're not calibrated, you may need a slightly different color set to minimize the font standing out.
Darkness. lvl 84 !!
203699-0
203701-1
203703-2
Offline vanderzee
Re: dark theme?
« Reply #3 on: Sun, 16 September 2018, 11:04:10 »
thanks really, hard to see with the bright background, after looking hard there is indeed a small tab to change the theme (very hard to see?!)
thanks a lot
:thumb:
sadly that Color Toggle does not work on waterfox 56 (i abandoned firefox a very long time ago)
but i will remember the  #454545 - seems really a great color
thanks!
« Last Edit: Sun, 16 September 2018, 11:10:37 by vanderzee »
Re: dark theme?
« Reply #4 on: Sun, 16 September 2018, 16:13:14 »
Nostalgia > every other theme
Re: dark theme?
« Reply #5 on: Sun, 30 September 2018, 00:38:09 »
+1
Nostalgia++
