Author Topic: Good modern clicky switch?  (Read 2766 times)
Offline soupman
« on: Sun, 30 September 2018, 22:27:59 »
Hey guys,
I'm pretty new to this keyboard thing and I'm planning on building my own mech. What are some good modern clicky switches I can use?
Thank
Offline ollir_
Re: Good modern clicky switch?
« Reply #1 on: Mon, 01 October 2018, 09:53:05 »
SMK switches of course!  You can get them in MX mount and they are one of the betters imo.
« Reply #2 on: Mon, 01 October 2018, 10:41:32 »
those box switches from kailh is the perfect choice for u. modern and better than cherry mx imo. good luck with your build :thumb:
Offline soupman
« Reply #3 on: Mon, 01 October 2018, 22:38:18 »
Thank you! I am leaning toward the box navies. Where would I get an smk compatible pcb?
« Reply #4 on: Tue, 02 October 2018, 00:11:36 »
Dont really knnow since i put them in a cheap hotswpable board. But I think you can find lots of them pcb on Bang good or Ali Express
Offline ollir_
« Reply #5 on: Tue, 02 October 2018, 00:19:14 »
From LFKeyboards at least
« Reply #6 on: Tue, 02 October 2018, 10:19:51 »
the new Click bar switches really gives you THAT FEELS..
buhhh.. it's annoying as heck when you're trying to relax.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Tue, 02 October 2018, 11:11:17 »
They're not modern. But they are better than any modern switch xD .
Offline ollir_
« Reply #8 on: Tue, 02 October 2018, 15:37:23 »
Shhh!! No-one needs to know!
« Last Edit: Tue, 02 October 2018, 15:39:17 by ollir_ »
Offline ollir_
« Reply #9 on: Tue, 02 October 2018, 15:37:49 »
.. nvm this was mistake post :D
