Author Topic: [IC]Volcano660, Gasket Mount Keyboard(Half a year, FINALLY, GB is Live!)  (Read 236408 times)
Offline KaosJ
Re: [IC]Volcano660, Gasket Mount Keyboard(Final Design Updated in!!!!28th/Oct)
« Reply #100 on: Sun, 28 October 2018, 17:29:01 »
Here is a short IC form for you:
https://goo.gl/forms/FCM1S8zj8sIvHtne2
how expensive will the full brass option be?
Don't need to know, just open your heart (and your wallet) and pick that full brass option  ;)
Offline Dovan1405
« Reply #101 on: Mon, 29 October 2018, 08:29:54 »
In for poly carb
Offline kakan
« Reply #102 on: Mon, 29 October 2018, 08:30:59 »
In for poly carb
I'm too, sadly it seems like he will only raffle them away  :(
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
Re: [IC]Volcano660, Gasket Mount Keyboard(Render is updated in!!!1st/Nov)
« Reply #103 on: Wed, 31 October 2018, 22:50:57 »
so far has 68 responses. 30% want to have fully brass build raffles and 40% want the PC version.
Offline Mcnos
    • GMK Fuyu
« Reply #104 on: Wed, 31 October 2018, 23:36:06 »
I think PC is the way to go. Brass just tarnishes easily and I don't see the point of having an all brass board, but that is just only my opinion. People may like it, but I love me some 66
Offline KaosJ
« Reply #105 on: Thu, 01 November 2018, 04:53:10 »
Not sure if the IC form was abused initially or something but is really strange that PC has a 40% (unexpected i would say).
To be honest, if that's the only option, i pass. Not going to spend more than alu for "deluxe plastic".
Regarding your concern, full brass should be also PVD and also any brass would be covered to prevent oxidation.
Hopefully, there will be multiple optiona to make the top choices happy with it.
Offline Dovan1405
« Reply #106 on: Thu, 01 November 2018, 11:00:42 »
Nothing unexpected about it. Polycarb boards are pretty hyped now a days.
Also having multiple options will be difficult with pricing and stuff. But we can also see what louis will open for us. The more the merrier of course.
Offline taropaste
« Reply #107 on: Thu, 01 November 2018, 12:51:22 »
any thoughts of having a polycarb version of this? and also options of other materials for the plate like copper, stainless steel and so on.... :D
Plate default will be brass. Stainless steel maybe cannot.
Polycarbonate body will be cool options ,how about raffles them?
@KaosJ, based on what Louis said (I quoted above) and what was on the google form, I'm pretty sure he was just exploring what people might want for a special limited number of boards which he would raffle off (poly or full brass). The main group buy would be normal aluminum versions. I'm sure he'll clarify but I don't think there's any reason for concern :).
Also, I'm hyped for the potential of a poly version!!
« Last Edit: Thu, 01 November 2018, 12:53:13 by taropaste »
Offline ilouis_07
    • ILUMKB
« Reply #108 on: Thu, 01 November 2018, 21:37:02 »
thanks for the answer @taropaste. YES, the main gb version will be:alum top and bottom case, Brass plate and weight. In IC form, raffles sale for PC or full brass version, i will do limited kits for raffles only.
« Last Edit: Thu, 01 November 2018, 22:43:57 by ilouis_07 »
Offline ilouis_07
    • ILUMKB
« Reply #109 on: Thu, 01 November 2018, 21:43:27 »
I changed USB port to Type C, i think type C is the future :D maybe.
Offline Dovan1405
Re: [IC]Volcano660, Gasket Mount Keyboard(Type C is updated!!!2rd/Nov)
« Reply #110 on: Fri, 02 November 2018, 00:46:38 »
Time for a new cable then
Offline ilouis_07
    • ILUMKB
« Reply #111 on: Fri, 02 November 2018, 03:29:37 »
correct me if i am wrong. I tot, type c can allow more current flow in to the circuit, but pcb doesn't have rgb underglow. Type C consider more secure and it is reversible(user friendly:P).
Offline _ODIN_
« Reply #112 on: Fri, 02 November 2018, 03:41:39 »
Did you consider the copper plate?
Gesendet von meinem H8416 mit Tapatalk
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #113 on: Fri, 02 November 2018, 03:48:49 »
Just curious, will there be an option to customise the design on the weight?
Offline ilouis_07
    • ILUMKB
« Reply #114 on: Fri, 02 November 2018, 04:19:09 »
you meant engraving some words on it?
Offline The Raygin Asian
« Reply #115 on: Fri, 02 November 2018, 13:11:11 »
Filled out the IC! How long until the GB do you think? If it's a month out I'm definitely in.
Offline ilouis_07
    • ILUMKB
« Reply #116 on: Fri, 02 November 2018, 22:54:10 »
GB SHOULD be next month. i can't confirm yet, i am still looking for prototyping factory now.
Offline slxdegrees
  • Nerds With Keebs
« Reply #117 on: Sat, 03 November 2018, 03:02:17 »
Yes, like what Gray Studio had for the COD67.
Offline ilouis_07
    • ILUMKB
« Reply #118 on: Sat, 03 November 2018, 04:02:11 »
i have been thinking about it also. But so far i haven't decided prototyping factory yet. Need more time to answer this Question but i will try for sure:)
Offline ilouis_07
    • ILUMKB
« Reply #119 on: Sun, 04 November 2018, 06:37:01 »
update: Type C for PCB.
Offline bobdenard
« Reply #120 on: Sun, 04 November 2018, 07:14:43 »
Is Bluetooth still a possibility? Was really looking forward to it.
Offline pino38
« Reply #121 on: Sun, 04 November 2018, 07:23:52 »
price est on the full brass version?
Offline ilouis_07
    • ILUMKB
« Reply #122 on: Sun, 04 November 2018, 07:29:09 »
sorry, no BT version PCB on this time.
Offline ilouis_07
    • ILUMKB
« Reply #123 on: Sun, 04 November 2018, 07:30:27 »
Before the GB i will announce it, thanks:)
Offline KaosJ
« Reply #124 on: Sun, 04 November 2018, 07:42:40 »
kailh hotswap sockets yay or nay?
Offline pino38
« Reply #125 on: Sun, 04 November 2018, 07:52:25 »
yay!
Offline ilouis_07
    • ILUMKB
« Reply #126 on: Sun, 04 November 2018, 07:53:20 »
nope, sorry
Offline Jedi
« Reply #127 on: Sun, 04 November 2018, 10:28:20 »
I have to give you props man.  From a design perspective you've nailed most every aspect in designing this case, the plate, the weight, the profile, keycap setting, I am very interested in your review of the prototype.  Judging based on the number of views on this IC, you'll have no issue with selling.  Good luck on the prototype!
Offline ilouis_07
    • ILUMKB
« Reply #128 on: Sun, 04 November 2018, 10:36:52 »
Offline Mcnos
    • GMK Fuyu
« Reply #129 on: Sun, 04 November 2018, 10:39:07 »
Will you be stocking extra pcbs?
Having the type c port on the case makes it proprietary to the certain pcb you're using as no others are using type c
Offline V. Vega
« Reply #130 on: Sun, 04 November 2018, 10:41:01 »
I'm really interested in this. I don't have anything in this layout and I'm super curious about gasket mount designs so I hope you're able to offer it in some nice fun pastel colors!
I'll be sad if it only comes in colors like black, red, and silver.
Offline KaosJ
« Reply #131 on: Sun, 04 November 2018, 10:50:11 »
To be honest there are other type-c 65%.
Surely that's just a plus over the dinosaurs still using mini-usb in 2018 ;D
Offline taropaste
« Reply #132 on: Sun, 04 November 2018, 12:03:42 »
This isn't a 65% layout :rolleyes:. The only 66% pcb that is readily available is the clueboard and that does not use usb c. It looks like the new clueboard low profile pcb is usb c but that one is also hotswap. I don't know if skully plans on releasing a non-hotswap with usb c anytime. Louis, I would honestly prefer the volcano remain compatible with the clueboard pcb. I don't have the most confidence in Percent's pcbs after what happened with the Canoe. I know there are some others who feel the same way but I don't know if that is the a lot of people. Maybe do another google form for usb c vs clueboard pcb compatibility? Lol.
I don't know ...obviously it's your decision. I'm just offering my opinion. By the way, thank you for being so responsive with your IC. You're doing a great job :thumb:.
Offline KaosJ
« Reply #133 on: Sun, 04 November 2018, 17:52:49 »
IKR i think answering this while watching the Space65 mixed my thoughts :D
I agree about the percent part. I doubt it will happen again but why taking the risk. Better avoid unless we are talking about that sweet clear pcb, in that case i would take the risk.
The only thing that is on priority to me regarding the pcb is TYPE-C and QMK. Nothing else. I wouldn't buy any bootmapper pcb, probably same logic for the connector unless the design is really outstanding and blowing my mind.
« Last Edit: Sun, 04 November 2018, 17:55:54 by KaosJ »
Offline regionfree
« Reply #134 on: Sun, 04 November 2018, 18:37:23 »
I have the same opinion about Percent. The MAO Canoe I got had pcb issues (luckily I was able to fix it), and the quality of the finish is nothing compared to the China MAO version. I got the impression that they really don’t care about quality for int’l buyers as we won’t be able to chase them for issues.
That said, I’m avoiding Percent products like the plague, and honestly, will be a dealbreaker for me if they would be the pcb provider.
« Last Edit: Sun, 04 November 2018, 18:39:20 by regionfree »
Offline ilouis_07
    • ILUMKB
« Reply #135 on: Sun, 04 November 2018, 20:02:37 »
Definitely will. Currently i am working closely with clueboard skully on the PCB also. Both of us want to provide high end quality product:D
Offline ilouis_07
    • ILUMKB
« Reply #136 on: Mon, 05 November 2018, 02:18:33 »
Actually they did all the free replacement when the pcb has problem (in new condition) in china domestic. But for international gb, i am not sure what is going on but sorry to heard that bro:(, PCB is the core for a keyboard and I'll give you a satisfactory answer in the end :)
Offline missylo
« Reply #137 on: Tue, 06 November 2018, 07:13:23 »
really stoked to see that your project has gone so far!! looking forward to it!
Offline TheMastermind
« Reply #138 on: Tue, 06 November 2018, 22:07:23 »
I don't know if it has already been asked but is the GB FCFS or a limited time frame? If it's the latter count me in!
Offline Abec13
« Reply #139 on: Wed, 07 November 2018, 08:03:05 »
Would also like to know this. I was gonna buy a KOYU but this talked me out of it.
Sent from my SAMSUNG-SM-G930A using Tapatalk
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline Funktion
« Reply #140 on: Wed, 07 November 2018, 10:22:01 »
Liking this more and more as it has evolved. Tell me it won't be a limited run though. I don't want to fight for a spot of 1 of 50 or something like that.
Offline ilouis_07
    • ILUMKB
« Reply #141 on: Wed, 07 November 2018, 21:03:51 »
Hi, it will be open slots for default kit(alum body+brass plate and brass weight) and raffles for PC/Fully brass kits.
Offline ilouis_07
    • ILUMKB
« Reply #142 on: Wed, 07 November 2018, 21:06:20 »
Haha, you don't need to fight, it is open slots for default kit.
Offline joe405
« Reply #143 on: Thu, 08 November 2018, 05:27:13 »
Hmm in that case how about providing an option for the hotswap PCBs used for the clueboard LP? There's a split space version too.
Offline pino38
« Reply #144 on: Thu, 08 November 2018, 05:34:52 »
will the losers of the brass version raffle  have a window to still pick up an aluminum version?
I want to go all in on a brass, but if i don’t get selected as a winner, i still want to be able to purchase an aluminum :D
Offline Geckt
« Reply #145 on: Fri, 09 November 2018, 00:47:27 »
Don't think you really need to worry about that.
I believed all these questions have been thought out before, he's very attentive to all these little details.
Offline Eri Kasamoto
« Reply #146 on: Fri, 09 November 2018, 10:43:48 »
I'm new and I'm in!
Really hoped that it would have came in a full brass option instead of having to go through a raffle.
Looking forward to the GB e-mail!😁
Offline ilouis_07
    • ILUMKB
« Reply #147 on: Fri, 09 November 2018, 10:54:03 »
We are hoping get some anodized colour samples from the factory. These would be to test the accuracy of anodizing of colours and are not the finalised colours of the Volcano660
Offline Geckt
Re: [IC]Volcano660, Gasket Mount Keyboard(Change in PCB and Colors /Nov 10)
« Reply #148 on: Fri, 09 November 2018, 12:11:54 »
It must hit a minimum MoQ, and raffles for the limited quantity PC/Brass kits.
Just watch the thread please, thank you very much. :) He will be releasing news frequently as soon as he gets new prototyping materials
« Last Edit: Fri, 09 November 2018, 12:20:58 by Geckt »
Offline KaosJ
« Reply #149 on: Fri, 09 November 2018, 12:13:58 »
U L T R A V I O L E T
