Author Topic: [IC]Volcano660, Gasket Mount Keyboard(Half a year, FINALLY, GB is Live!)  (Read 234558 times)
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
Re: [IC]Volcano660, Gasket Mount Keyboard(Change in PCB and Colors /Nov 10)
« Reply #200 on: Sun, 18 November 2018, 19:00:10 »
God I'm so excited for this guy. Heavy, 66%, Gasket mount... I just hope that since the PCB will be from clueboard, that getting extras won't be hard. USB-C or Mini, do you think?
USB C, this is customized version pcb done by clueboard. Because I have 3 LEDs here.
Offline ilouis_07
    • ILUMKB
« Reply #201 on: Sun, 18 November 2018, 19:01:42 »
I think I will try a 6u space bar with this board for the first time. The symmetry of the bottom row is amazing.
Gesendet von meinem H8416 mit Tapatalk
Yup that’s why I want to put this 6u spacebar here, also kbdfans has 6u wire, I will ask some for V66 GB.
Offline _ODIN_
« Reply #202 on: Mon, 19 November 2018, 01:53:12 »
Nice
Offline ilouis_07
    • ILUMKB
« Reply #203 on: Tue, 20 November 2018, 06:39:08 »
Color sample plates will finish in 2 days. i am excited :)
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #204 on: Tue, 20 November 2018, 08:15:41 »
Can't wait! Will be my first gasket mounts board. Can't wait to try out!!
Offline ilouis_07
    • ILUMKB
« Reply #205 on: Wed, 21 November 2018, 22:54:13 »
That’s sick !!!!!!
Offline Windeh
  • a no name
« Reply #206 on: Wed, 21 November 2018, 23:14:46 »
Oof and it begins!  :thumb:
Offline KaosJ
« Reply #207 on: Thu, 22 November 2018, 16:49:14 »
That’s sick !!!!!!
Yo that's a big boye :eye:
Waiting for brass as well!
Offline missylo
« Reply #208 on: Tue, 27 November 2018, 23:05:49 »
That’s sick !!!!!!
Nice
Sent using Tapatalk
Offline Geckt
« Reply #209 on: Wed, 28 November 2018, 12:44:46 »
That’s sick !!!!!!
This, looks like my bar of chocolate in aluminum foil.
Offline Rubbermilitia
« Reply #210 on: Wed, 28 November 2018, 13:16:03 »
Extremely excited for this. By far the best looking gasket mount system I've seen so far
Offline ninjacore
« Reply #211 on: Wed, 28 November 2018, 22:38:56 »
Is gasket mount better for a particular switch style? I want to pickup either a top mount or gasket mount board, but I haven’t owned either (only owned pcb-to-tray-mount boards so far). I’ll be building w zealios.
Win me over! ;)
Thanks
Offline Mcnos
    • GMK Fuyu
« Reply #212 on: Wed, 28 November 2018, 23:07:30 »
Win me over! ;)
Thanks
I think the gasket stands out with linears, not sure about tactiles. Could have a great effect to it but I can't speak on gasket's behalf.
« Reply #213 on: Wed, 28 November 2018, 23:28:34 »
Win me over! ;)
Thanks
I would actually argue the opposite, conventional wisdom is that plates with more flex are better for tactile (like acrylic, fr4) while stiffer plates are better for linear (aluminum, brass, SS). This is because a bit of flex compliments the feeling of a tactile switch, whereas linears feel the most 'clean' when on a nice solid plate.
Since gasket mount introduces another level of flex/bounce (for lack of better words), conventional wisdom would probably side with tactiles working better on gasket mount.
But keep in mind that none of the above is universally relevant, and is always very subjective. For example, if you love to bottom out your switches, you don't want a SS plate because its way too rigid and will just hurt your fingers- therefore a bit of flex introduced by the gasket mounting could be welcome. But if you type lightly and never bottom out, you might want a more solid build.
And everything above this line is pretty much BS cause you like what you like. Try everything
Offline Starston3
« Reply #214 on: Wed, 28 November 2018, 23:31:16 »
Win me over! ;)
Thanks
That last line pretty much sums it up. This entire hobby is about personal preference so everything is subjective.
Offline missylo
« Reply #215 on: Wed, 28 November 2018, 23:40:09 »
...For example, if you love to bottom out your switches, you don't want a SS plate because its way too rigid and will just hurt your fingers- therefore a bit of flex introduced by the gasket mounting could be welcome. But if you type lightly and never bottom out, you might want a more solid build.
YASSSS!!! it is subjective.
i bottom out linear switches (light linears) and the brass doesn't feel so great for me
Offline Proer47
« Reply #216 on: Thu, 29 November 2018, 00:06:55 »
Count me in for 1!
Offline KaosJ
« Reply #217 on: Thu, 29 November 2018, 01:29:55 »
There is just one acceptable material for plates for me: Brass.
THOCC THOCC THOCC
Offline ilouis_07
    • ILUMKB
« Reply #218 on: Thu, 29 November 2018, 08:28:44 »
Still PVD? No way, this time is Chroming !
从我的 iPhone 发送,使用 Tapatalk
Offline ninjacore
« Reply #219 on: Thu, 29 November 2018, 11:41:52 »
Thanks, everyone.  That's basically what I assumed.
Offline merlin64
    • MechMerlin
« Reply #220 on: Thu, 29 November 2018, 13:54:16 »
oooooh soo shiny! I'm getting super excited about this.
Offline The_judge_168
« Reply #221 on: Fri, 30 November 2018, 00:18:20 »
Looks good. And yay ANSI only plate
« Reply #222 on: Fri, 30 November 2018, 00:22:16 »
a beauty
Offline KaosJ
« Reply #223 on: Sat, 01 December 2018, 06:59:47 »
a beauty
HOT AF
Offline appaboy
« Reply #224 on: Sat, 01 December 2018, 22:53:57 »
Joining this as soon as it happens.
ansi plate only? bummer
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
« Reply #225 on: Sat, 01 December 2018, 23:48:36 »
5. support for ISO plate available
Offline missylo
« Reply #226 on: Sat, 01 December 2018, 23:50:09 »
Sent using Tapatalk
Offline KaosJ
« Reply #227 on: Sun, 02 December 2018, 08:32:38 »
As long as other layouts are included in other plates and not in the standard one which i would like with only ANSI, It's ok
Offline bluesclera
« Reply #228 on: Sun, 02 December 2018, 12:49:31 »
I wish someone would make a ALPS pcb for this keyboard.
Offline lendflat
« Reply #229 on: Sun, 02 December 2018, 14:09:58 »
Can it stick my Leopold fc660m pcb into this housing?
Offline ilouis_07
    • ILUMKB
« Reply #230 on: Sun, 02 December 2018, 18:49:38 »
We did it, alps compatible
Offline bluesclera
« Reply #231 on: Sun, 02 December 2018, 18:53:01 »
whhhhhhhhhhhhhhhhat??? the pcb alps compatible? still need a different plate right? TELL ME MORE!!
Offline ilouis_07
    • ILUMKB
« Reply #232 on: Sun, 02 December 2018, 18:57:26 »
For pcb, Clueboard made this happened. Plate I will work on it.
Offline bluesclera
« Reply #233 on: Sun, 02 December 2018, 18:59:43 »
oh sweet..thank you, thank you, thank you.
Offline ilouis_07
    • ILUMKB
« Reply #234 on: Mon, 03 December 2018, 21:16:30 »
I just set up a server, for better communication and progress updates purpose, feels free to join:)
TianYue Lab Discord Link:
https://discord.gg/cdQfxt
Offline Dolas
« Reply #235 on: Wed, 05 December 2018, 12:06:59 »
discord invite expired.  can i get another?
Offline sJ1N
« Reply #236 on: Wed, 05 December 2018, 15:06:27 »
Please also post any updates here, im eagerly waiting for this :)
Offline ilouis_07
    • ILUMKB
« Reply #237 on: Wed, 05 December 2018, 18:46:51 »
Prototype finished last week, waiting for pcb prototype from clueboard.
Offline ilouis_07
    • ILUMKB
« Reply #238 on: Wed, 05 December 2018, 21:51:42 »
here we go, https://discord.gg/VMkbkS
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC]Volcano660, Gasket Mount Keyboard(Prototype finished, waiting for PCB now)
« Reply #239 on: Sat, 08 December 2018, 09:21:00 »
 It's still expired, you might need to change the invite settings to allow unlimited invites
Offline ilouis_07
    • ILUMKB
« Reply #240 on: Sat, 08 December 2018, 09:22:53 »
here is a new link, feels free to join:)
https://discord.gg/AXC6VQ
Offline Abec13
« Reply #241 on: Sun, 09 December 2018, 14:58:03 »
Ugh I love this. It's like a Norbafoce but for a MX 66% which is the superior layout IMO. can't wait to pick one of these up. Just not sure on what color yet.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #242 on: Sun, 09 December 2018, 17:30:15 »
I wonder how holy pandas or vintage blacks would sound in this case... I hate hallow cases, the design looks clean and well made might join. :)
Offline ilouis_07
    • ILUMKB
« Reply #243 on: Sun, 09 December 2018, 21:35:36 »
updates: 10th Dec 2018
Clueboard have sent V66 pcb file to PCB factory in USA, so this PCB will be Made in USA.
est time end of Dec.
Offline travwal
« Reply #244 on: Mon, 10 December 2018, 11:47:57 »
Is the white case color going to be possible that is shown in the renders? It's beautiful!
I have heard that a white finish is fairly tough to achieve.
Offline ilouis_07
    • ILUMKB
« Reply #245 on: Mon, 10 December 2018, 23:33:42 »
well, my design purpose for v66 is solid typing sound. I will do some typing sound videos after i received everything. probably gonna use lubed(krytox 105) retooled black.
Offline Sharafaldin
« Reply #246 on: Tue, 11 December 2018, 09:21:57 »
This is exactly what i've been looking for! Just at the right time too! Will you be selling these only as a GB or at later moments too? Just wondering if i can wait or if i should jump aboard immediately
Also, about that discord link  :D
Offline ilouis_07
    • ILUMKB
« Reply #247 on: Tue, 11 December 2018, 19:13:37 »
Only GB:)
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #248 on: Wed, 12 December 2018, 04:43:47 »
yes retooled black sounds like a good idea. I have of these as well let us know when you release sound samples :D
Skickat från min iPhone med Tapatalk
Offline ilouis_07
    • ILUMKB
« Reply #249 on: Thu, 13 December 2018, 21:17:36 »
Thanks for my factory, this is the best Christmas gift ever:) Just on time !!!!
