Author Topic: LED Displays: Old vs New  (Read 3985 times)
Offline Olumin
  • "Guy walks into a doctor's office..."
« on: Fri, 19 October 2018, 14:12:58 »
What is the difference and why do the old ones look so much better?
Brighter, sharper, more colourful... Old LED displays on calculators, clocks, watches etc. just look so much better..
..in general anyway. Im sure there are exceptions...
Is it just down to less efficient devices and therefore higher powered LED's resulting in higher brightness?
EXAMPLE: OLD LED display:
And new NEW LED displays:
Offline Olumin
Re: LED Displays: Old vs New
« Reply #2 on: Fri, 19 October 2018, 15:39:23 »
Tp4 prefers VFD . !!
Yes! Me too.
I have a calculator like that one somewhere. Privileg brand I think.
« Reply #3 on: Sun, 21 October 2018, 20:49:28 »
Maybe running at 3.3V instead of 5V (or higher)?
Offline invariance
  • ...here with all the other boson's
« Reply #4 on: Mon, 22 October 2018, 01:22:26 »
Put a vfd on a build to display what layer your on
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #5 on: Mon, 22 October 2018, 06:33:12 »
Could it have something to do with the old covers being thicker and not crystal clear so adding a bit of fuzziness?  The modern ones all have gaps in the corners which just looks bad.
« Reply #6 on: Mon, 22 October 2018, 09:45:53 »
Modern ones are LED backlit LCDs.. The big numbers are big LCDs with tiny LED backlit.   This works fine for smaller displays because the led is the size of the lcd. but big ones look lackluster.
No one is using VFDs anymore.
