Author Topic: Bed split keyboard ergonomics  (Read 9691 times)
Offline Squarism
« on: Thu, 13 December 2018, 22:43:58 »
Like many others I sit at the office all day, In my mid 40ies I feel my ass can't do more than 8h office sitting. So I'm planning on creating a viable bed working environment. It's harder than I thought though and will probebly involve some type of special tenting/mounts. Planned on using an ergodox or soon a dactyl manuform. I wonder if anyone else have gone down this route or just have had the same urge?
Basically I want to keep the both halves near the outsides of my hips with a near vertical tilt. I also understood I need them raised relative bed surface as arms need to be slightly bent.
To find the right angles and coordinates I'd need to find a way of rapid protyping. My first idea was to use some type of clay/play dough. But I imagine I'd need litres of it.
The final solution would ideally need to have combined armrests attached to the keyboard mounts.
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
Re: Bed split keyboard ergonomics
« Reply #1 on: Fri, 14 December 2018, 06:21:01 »
People have done this with the Keyboardio Model01 and gorilla pods.
Offline ErgoMacros
« Reply #2 on: Fri, 14 December 2018, 11:38:12 »
Cutting, shaping and gluing "stiff" foam rubber may be faster and cheaper than clay and accurate enough at least for the first few iterations.
Good luck.
Today's quote: '...“but then the customer successfully broke that.”
« Reply #3 on: Fri, 14 December 2018, 22:44:55 »
Well you can sit up in bed and do this.
But unfortunately it's impossible to do computer stuff with your head in a pillow laying flat or near flat.
The problem is Cranial pressure.
When you're sleeping, your blood pressure drops enough such that you don't get a headache.
However, if you lay flat in bed, while awake for extended periods, you WILL get a headache, because the wakeful blood pressure ontop of the pillow pressure on your neck (compressing arteries) is overloading for the brain.
How do I know,  I've tried it..
At the end of the day, Couchputering is much more practical..
Offline Squarism
« Reply #4 on: Sat, 15 December 2018, 02:10:05 »
Ive spent 1000s of hours programming in bed with a laptop on my hip. Never felt that. Maybe tis an individual tjing.
« Reply #5 on: Sat, 15 December 2018, 10:05:25 »
I'm talking about laying flat,  if you're just sitting in bed, it works fine, just as well as sitting anywhere else.
Offline Squarism
« Reply #6 on: Sat, 15 December 2018, 22:33:31 »
Thats what I meant too. No sittning, 100% horizontal.
Offline BundleOfJoysticks
« Reply #7 on: Sun, 16 December 2018, 01:49:14 »
Kinesis used to make something that fits your requirements re. hands wide apart and mounting.
https://deskthority.net/wiki/Kinesis_Evolution
« Reply #8 on: Sun, 16 December 2018, 04:04:44 »
are you facing up or the side ?
