Author Topic: Logitech G-pr0 [Hero]  (Read 4997 times)
« on: Thu, 27 December 2018, 18:12:28 »
just got over christmas..
LOD on the gpr0 Hero sensor is a tad higher than gpr0 3366 sensor
The surface tuning feature is gone, but allegedly, the hero sensor has auto tuning which it does.
The main buttons feel -less substantial-, they're softer with a lighter finger response and dimmer click sound..
The cable is more flexible than the old thicker one.
Tracking is good as expected of all Logitech tuned sensors..
Hrrrm... wish there was a way to adjust the LOD manually like the 3366 version.
Overall, good mouse, Worthy iteration.
209592-0
Re: Logitech G-pr0 [Hero]
« Reply #1 on: Fri, 28 December 2018, 21:04:26 »
Rrrmm.... Really not digging the  new 50m omrons..
Just not as satisfying.
I'm guessing they went extremely aggressive on the overtravel limit to reach 50m testing, which is why they feel so shallow.
« Reply #2 on: Fri, 28 December 2018, 22:13:49 »
Screw it.. I'm going to cut it up and put it in a Vertical mouse..
« Reply #3 on: Sat, 29 December 2018, 09:44:12 »
Splice Completed.. the Gpro Hero is no more..
https://geekhack.org/index.php?topic=98764.msg2697911#msg2697911
209641-0
