Author Topic: Ergopwn 16K pr0 Hero [Vertical]  (Read 3357 times)
« on: Sat, 29 December 2018, 09:30:47 »
Ergopwn 16k is 10 grams lighter than Ergopwn 9000, due to not needing the usb hub and secondary mouse pcb.
-- Hero sensor
-- Jpn Omron D2F01F
-- Alps Rotary encoder 24 indent
This is a much simpler Splice vs Tp4's Ergopwn 9000.
The only slight difficulty was the usb cable, because it's at an odd position to fit into the shell, (had to solder wires from beneath).
Removed Huanos, got sick of them, sounds too bright.. Replaced with good ol' Weeaboo omrons, and Alps rotary encoder.
209633-0
209635-1
209637-2
209639-3
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Ergopwn 16K pr0 Hero [Vertical]
« Reply #1 on: Sat, 29 December 2018, 10:17:30 »
Looks great. But why post this in off topic?
« Reply #2 on: Sat, 29 December 2018, 10:18:58 »
Only OT contains the Full P0wr of Tp4's awesome..
Offline SBJ
  • Tactile pls
« Reply #3 on: Sat, 29 December 2018, 16:26:36 »
For some reason it reminds me of this:
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Sat, 29 December 2018, 16:52:18 »
Offline SBJ
  • Tactile pls
« Reply #6 on: Sat, 29 December 2018, 19:10:21 »
So, what do you use it for?
Just browsing forums or is there another reason you pimp out your mouse? Other than you can.
« Reply #7 on: Sun, 30 December 2018, 07:49:21 »
A bad mouse is like poorly fitted cloths or a bad pair of shoe.
It can increase stress
Cause Backpain
Even elevate risk of heart attack, stroke, and some cancers.
Joining the Gekhak community, we avert these risks through Soldering.
