Author Topic: Installed new graphics drivers..  (Read 2773 times)
« on: Sun, 30 December 2018, 14:08:58 »
Now Everything Crashes...
I'm just going to killz myself...
This pc doesn't have backup..
Maybe I should just throw it away.. instead of reformatting..
Why god whyyyyy
Offline Carcharocles
    • The Deathscape Mythos
Re: Installed new graphics drivers..
« Reply #1 on: Sun, 30 December 2018, 14:35:25 »
Use Display Driver Uninstaller, then go back to old drivers.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
T1000 , Firmware ver. Doge.
Most deadly of them all.
Offline Coreda
« Reply #3 on: Sun, 30 December 2018, 16:26:46 »
Restoring from a system restore point might help here, or if it was Nvidia try rolling back the driver via the device manager (if that's still an option).
« Reply #4 on: Sun, 30 December 2018, 16:41:10 »
I turned those off along with system protection because spying !! it's ok coreda, i'm just going to roll over and die
Offline Coreda
« Reply #5 on: Mon, 31 December 2018, 00:58:52 »
Wasn't aware of any spying shenanigans with restore points
Must be some way to fix it though, you can do it tp!
