Author Topic: Does screw-in stab any better than normal one ?  (Read 5711 times)
Offline M_Sang
« on: Fri, 01 February 2019, 00:17:41 »
Does screw-in stabilizer any better than normal one ?
I thinking of build a keyboard and got curious. where do you guy get good stabilzer ? that  not rattle even without lube.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: Does screw-in stab any better than normal one ?
« Reply #1 on: Fri, 01 February 2019, 01:05:57 »
I don't see a major difference between screw in and the regular one in terms of feel.
just make sure you use genuine gmk stabilizers. I've never tried zeal stabs or kbdfans ones so cannot say about these. chinese ones that are cheap, you should stay away. there is no way to make them not rattle.
Offline dexie
« Reply #2 on: Fri, 01 February 2019, 01:19:56 »
Screw-in stabilizers are not about reduced rattle. They mostly prevent tearing stabilizers off the board. You won't likely tear your normal stabilizer easily, but it really sucks if happens.
ISO Life
Offline M_Sang
« Reply #3 on: Fri, 01 February 2019, 03:20:40 »
thank you both of you.
Offline ander
  • I type, therefore I am
« Reply #4 on: Sun, 03 February 2019, 05:28:05 »
Does it do what better?
Offline _GMK_
  • not affiliated with GMK
« Reply #5 on: Sun, 03 February 2019, 05:56:01 »
I was quite sure that the only reason to buy screw stabilizers was the reduced wobble. Now that you people tell me that it isn't so, I see no reason to buy a set... Screw them  :))
Offline M_Sang
« Reply #6 on: Sun, 03 February 2019, 07:13:44 »
Do I need to be that specific ??
in being stabilizing and not rattle
Offline _GMK_
« Reply #8 on: Sun, 03 February 2019, 08:43:49 »
Which one tastes better?
Offline appaboy
« Reply #9 on: Sun, 03 February 2019, 08:51:08 »
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
