Advanced search
wanna switch?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Off Topic
GTX 1060 Ebay Buyer's Guide. (Old Miners)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: GTX 1060 Ebay Buyer's Guide. (Old Miners) (Read 1861 times)
tp4tissue
Destiny Supporter
Thread Starter
OmniExpert of: Rice, Top-Ramen, Ergodox, n Females
on:
Sat, 02 February 2019, 17:17:10 »
Nvidia GTX 1060
1:
CHECK the model number, there are so many iterations which look the same but may be very different.
For example, Evga's 1060 SSC/FTW/FTW+ (DT-versions), all may have the acx 3.0 cooler, and look the same, but they are NOT, only the FTW and FTW+ have 6+1 Vrm, whereas SSC have 4+1.
The SC and Non-SC model have 3+1, Single fan Acx 2.0 cooler, the Non-SC base-base model has NO heatpipes, it's the most budget model.
DT Versions, such as FTW-DT, SSC-DT means, it failed to meet FTW test standards, but still has the FTW board/vrm layout. It's not as good, but tbh, they're all worn to about the same point after mining for 2 years.
2.
Now that you know what you're buying, m0ar VRM = Better.
3.
What about Mining, will they blow up ?
Good question the answer is YES ! Especially the early released models many had Vrm/ Cooling problems, and Mining made that worse. Go back to step 1, You want 6 VRM minimum, look for FTW/FTW+ models or equivalent from other manufacturers.
4.
AVOID ALL Single-Fan models, These came out earliest, they run the hottest, they have lower vrm count, AND they've been stuck in mining for ~2+ years.
5.
Seller claims They didn't mine. OK, Check his Ebay SOLD and Completed listings, If there are 8 other 1060gtx or Rx580, RX570 in there, he's a LIAR.
6.
Grease spots, You'd often see evga cards and Gigabyte cards with this greasy/ spotty residue on the cards, This is silicone grease emanating out of the thermal pads. The pads are designed for this, and are typically fine, it's just not pretty.
If you care about the aesthetic of cards without backplates, you need to use brake cleaner to get the stain out, because alcohol will not remove it.
Functionally, it's fine. You can swap out the pads as well, (1.5mm), but unnecessary on higher models, lower vrm count models may benefit.
7.
If you're considering Team RED, RX580
ONLY buy Sapphire nitro models and Powercolor Red Devil models, avoid everything else. (especially XFX, plague)
The RX580 is faster than 1060 in many games. and for the ~Same Price, you get 8GB vs 6GB on 1060
1060GTX has better Video playback (Madvr) support.
Last Edit: Sat, 02 February 2019, 21:42:52 by tp4tissue
Logged
< Tp4 Keycap Project >
< Tp4 Typing Speed-Guide >
< Tp4 Rice Hydration Guide >
< Tp4 Agar.io Lessons >
< Geekhack Agar.io Team >
< Making DIY Mouse feet ? >
< Tp4's WMO Ultimate >
< Tp4's G100S >
< Tp4's Ethernet Cable Guide >
< Ergopwn 9000 >
< Tp4 External Harddrive Mod >
< Tp4 Air Filter >
< Cricket Wireless ? >
< Fastest MicroSD Card ? >
< Tp4 Comes to America >
< Olfa 9mm, The Sharpest >
< Logitech G403 Lags >
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Off Topic
