Author Topic: Traveling keyboard that comfortably sits OVER a MacBook Pro keyboard  (Read 2599 times)
Offline e2o
Does anyone have a good solution for a decent keyboard that comfortably sits *over* the built-in MacBook Pro keyboard? We can skip the brass weights and high-profiles - This will need to be light for traveling daily from client to client. I've tried keyboards in front of the machine, but that puts the display too far from my eyes, and reaching over it to get to the trackpad sucks (I don't want to carry a mouse). 65% preferred, but maybe a 60%. Bluetooth would be convenient but not necessary. Maybe I'm dreaming...
Re: Traveling keyboard that comfortably sits OVER a MacBook Pro keyboard
« Reply #1 on: Wed, 13 February 2019, 20:59:56 »
any 60 or 65 should be fine dimensionally
tada68 probably a good place to start
Offline Tactile
« Reply #2 on: Wed, 13 February 2019, 23:01:33 »
Sounds like you need one of these.
REΛLFORCE
Offline e2o
« Reply #3 on: Thu, 14 February 2019, 10:07:57 »
Offline postanthony3000
« Reply #4 on: Fri, 15 February 2019, 00:29:59 »
The Hexgears X1 might work well. I use one at work and I quite like it. And with that keyboard protector I might start doing the same.
Offline anantonton
« Reply #5 on: Fri, 15 February 2019, 01:50:20 »
I asked acrylic shop to make one for me, stuck six 3M rubber bases. Put a custom 60% on top of the "keyboard bridge". But my travel bag is now very bulky. because I have to carry everything and they're not exactly very thin and portable.
Offline Sup
« Reply #6 on: Fri, 15 February 2019, 05:13:33 »
There isn't much you can do sadly about this.
current
Coming soon
Offline swedishpiehole
« Reply #7 on: Fri, 15 February 2019, 15:56:11 »
I use my Planck with Datamancer case (https://www.reddit.com/r/MechanicalKeyboards/comments/an2pzy/planck_with_datamancer_case_and_devlin_teletype/)when I travel with my MacBook Pro. The freeware app Karabiner has a setting that will disable the internal keyboard when an external one is attached, so I can set it right down on top of the MacBook keeb and still use the trackpad.
« Reply #8 on: Fri, 15 February 2019, 16:49:58 »
It's very impractical to add just a large accessory to your laptop.
It may seeeeem like a good idea while you're in the -honeymoon phase- of your mechanical keyboard journey.
But advice from the mechanical ol'guys, the love fades quickly against encumbrance , until finally, you couldn't be bothered to extra-pack.
Offline ErgoMacros
« Reply #9 on: Fri, 15 February 2019, 18:42:31 »
Or, if the keyboard is wide enough, and only used for travel, skip the acrylic plate and just add rubber buttons to the keyboard.
Smaller, lighter.
Today's quote: '...“but then the customer successfully broke that.”
Offline e2o
« Reply #10 on: Mon, 18 February 2019, 15:35:01 »
I think I might build something similar, but I think I'll bring the bridge forward on both sides of the trackpad for wrist rests. This one is nice looking, but it looks like it puts the base of keyboard a good 1/2 to 3/4 inches above the laptop case. I already use a wrist wrest on my table to get my wrists at top-of-case height.
