Author Topic: Burning Videos to Blu-Ray Discs  (Read 4784 times)
Offline abdulmuhsee
« on: Mon, 04 March 2019, 22:13:23 »
So, I've downloaded several blu-ray burners and am apparently too stupid to figure out how to burn videos to disc.  I just want to put some videos on a disc and have them play in a blu-ray player, but they all ask me for BDMV or VIDEO_TS folders or something.  Is there software out there where I can just drop the files in a box and it makes me a video blu-ray?
Re: Burning Videos to Blu-Ray Discs
« Reply #1 on: Tue, 05 March 2019, 03:32:40 »
That isn't what you want to do.
Most smart tvs will play "many file formats" directly from a usb drive.
If that doesn't work.  You'd still want some sort of HTPC attached to the TV for best quality playback, or a laptop.
MPCHC + Madvr (software combo) is the highest quality Playback (signal wise) on the market. *(It's Free)
In terms of COST,  it's cheaper to buy Harddrives than it is to burn discs.
Offline abdulmuhsee
« Reply #2 on: Wed, 06 March 2019, 22:00:49 »
But... I want the shows in a case on the shelf XD.
« Reply #3 on: Wed, 06 March 2019, 22:26:58 »
Not against' displays,   but, the cost in this case is ~ 10:1.
The bluray burning programs require bluray structure, and the file must be in the right format. If they're re-encoded, you'd have to transcode them back into the original format and container.
