Author Topic: How often do y'all drink ?  (Read 17480 times)
Re: How often do y'all drink ?
« Reply #50 on: Fri, 12 April 2019, 22:08:10 »
Lmao. Actually I so rarely drink (like a handful of times in years) that I can definitely say it's the taste. That said most beers I've tried do taste bland though, Guinness is the only beer I've legitimately enjoyed the taste of and if it were possible to produce a non-alcoholic version I'd buy it.
As for the effect I dislike the dulling alcohol has on the mind. It's not entirely unlike valium in that way (took it prescribed once while recovering from concussion IIRC and it feels like one's mind has lost all sharpness). Obviously some like that aspect but along with hindering the metabolism of fat while the liver is trying to purge it from our bodies it's not ideal.
I mean this with no disrespect Coreda. But you misunderstand the EFFECT of alcohol.
The dulling of the senses, maybe nausea, stumbling, babbling, blurred vision.
All of those things are SECONDARY to the Dopamine Rush.
ALCOHOL = Happiness.   There is no if, but, also. it's a 1:1 analogy
That is how your brain interprets drinking, REGARDLESS of any other side effects.  for light drugs such as alcohol, tobacco, coffee, marijuana, snus,  these are the ~200% dopa triggers, Equivalent in chemical strength to natural high during (secs).
For example, Normally, when you throw up, your brain creates a memory , don't eat that again, or don't do whatever it is you did that made you throw up. BECAUSE it may have been poisonous.
Alcohol is different,  Even if it made you nauseous, and sick feeling, The brain still writes a Happy memory. Good job Coreda,  DO this more, do it all the time, you are awesome, keep drinking. That is how direct acting these chemicals are.
Jack daniel is no fool, he's not allowed to sell you heroin,  next best thing alcohol.
Offline Coreda
« Reply #51 on: Fri, 12 April 2019, 23:12:32 »
The dulling of the senses, maybe nausea, stumbling, babbling, blurred vision.  All of those things are SECONDARY to the Dopamine Rush.
ALCOHOL = Happiness. That is how your brain interprets drinking, REGARDLESS of any other side effects.
I'm talking about enjoying the taste of a specific beer though. If we instead look at wines there are probably more varieties you would agree have a pleasant flavor. I mean, I find it hard to believe you'd consider all alcoholic drinks taste the same and any opinions on taste are entirely based on positive brain re-enforcement. Seems more likely there just haven't been any beer flavors you'd liked.
Remember, most beer I didn't enjoy the taste of (that fwiw aren't associated with bad experiences either, in fact the opposite), which put me off having beer for the longest time so I'm not coming to the opinion I enjoy a particular taste solely from some effect it had.
I understand some drink simply for 'happy' factor but I drink so rarely to care for it so when I have the consideration was down to taste. In a way it's like a light, non-sweet but distinctively tasting soda which is nice when one isn't after something overbearing and pairs well with some food combinations. The downsides regarding fat metabolism and the mind dulling aren't worth it though, personally.
« Last Edit: Fri, 12 April 2019, 23:14:19 by Coreda »
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #52 on: Fri, 12 April 2019, 23:56:58 »
Drinking generally makes me sleepy so I usually have a tequila once my kiddos are in bed and I'm winding down, getting through some e-mails or chatting with y'all.
« Reply #53 on: Sat, 13 April 2019, 00:39:47 »
I don't disagree that the preference of taste exists, or that someone might enjoy a typically disagreeable taste.
HOWEVER, in the case of ALCOHOL,  what it tastes like does not matter.
For example, your first ever cigarette.  You probably dragged on it a bit too hard, took smoke all the way into the lungs,  coughed, painful.
That AWFUL sensation is a way of life for smokers.  How did that happen, how COULD it happen.
That's the power of 200% dopamine lvl, and -desensitization- (with continued use).
It doesn't take much, it's EXTREMELY pleasurable, you may not even be aware of how good you feel, but every time you imbibe, your brain jots down in its chemical recorder, Hurray, we did it again guys, we've conquered LIFE.
It's not as Obvious as Cocaine/Meth, but it's at the PEAK lvl as ordained by nature, Beyond which is neurotoxic..
« Reply #54 on: Sat, 13 April 2019, 01:04:33 »
I don't think people drink to be happy. I think they either drink to socialize, or as an escape. Any type of drinking can fall under those two categories.
« Reply #55 on: Sat, 13 April 2019, 01:10:19 »
The Happy,  happens regardless of anything else going on.
They can be waterboarding you,  if you're doped up,  the brain registers the experience as pleasurable, DESPITE you knowing obviously that waterboarding is not fun at all.
This is why addicts against all adversity can Continue doing what they're doing.
Drugs = Happiness , anything or any proximal behavior towards drug use = DO IT MORE.
People encrust drug-use with All sorts of colorful language and depictions.  But it's all mere embellishment of a hard Truth.  Chemical happiness = REAL HAPPINESS.
« Reply #56 on: Sat, 13 April 2019, 01:32:55 »
But happiness is a result, not the catalyst. The force that drives someone to a substance is not happiness, but an activity that they hope results in feelings of happiness. Sometimes.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #57 on: Sat, 13 April 2019, 02:53:09 »
When I'm not with people, I genuinely drink for the taste. Come to think of it, that's probably why I don't have cheap alcohol in my house xD .
« Reply #58 on: Sat, 13 April 2019, 08:06:29 »
Nope.
That's not how the hedonic system works.  it's ALL about the happiness.
The only reason , anyone can enjoy any activity, is if that activity serves SOME function which leads to or increases the probability of -Happiness-.
And once happiness is achieved, the brain writes down a memory, this + this + this works. Do this more tomorrow.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #59 on: Sat, 13 April 2019, 11:22:28 »
Nope.
So what about dopamine hits from THC?  Would that be a Groundhogs Day effect scenario?
« Reply #60 on: Sat, 13 April 2019, 11:51:04 »
Marijuana shouldn't be schedule 1.
However, it is as powerful and addicting as cigarettes/alcohol
Addicts are playing into the hands of cigarette companies all over again.
You think all these giant weed companies arose from mom-pop operations ?
Heck no, It's all shadow banking funded by the likes of philip morris
The only reason they stopped with the cigarette, was because of Public outcry against.
Now that these dumb kids cry out FOR marijuana, well, here we go again. hahaha. round and round.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #61 on: Sat, 13 April 2019, 12:15:53 »
Tonight. A lot.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #62 on: Sat, 13 April 2019, 12:34:54 »
I've read quite a few articles published in the last couple years about less than legit farms (California) that redirect streams to satisfy massive water requirements.
As a previous recreational user and supporter (still) of legalization I wasn't aware that each plant requires ~6 gallons of water per day.
They're is some worry that legalization in Florida might significantly drain 'the aquifer'.  I am a bit worried about that tbh--they can desalinize salt water too but at what cost to the environment?
I need to watch Groundhog Day again...
« Reply #63 on: Sat, 13 April 2019, 12:37:45 »
Humans, short memories.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #64 on: Sat, 13 April 2019, 12:52:06 »
« Reply #66 on: Sat, 13 April 2019, 15:15:59 »
As someone who used to grow, 6 gallons of water a day is complete and total horse****. Not only do they barely go through 1 gallon a day per plant, but even using a hydroponic system that DOESN'T recycle water(like 99% of them do) you STILL wouldn't get through 6 gallons a day. That number is 100% fabrication on every single level of inspection.
« Reply #67 on: Sat, 13 April 2019, 15:41:35 »
It's different growing inside vs out.
I don't know which one they refer to,  But Just growing tomatoes outside, summer time , use LOTS of waters, same with melons.
The use of water is a debate mainly because they're growing a narcotic.  It's not a food.
« Reply #68 on: Sat, 13 April 2019, 15:44:21 »
6 gallons a day for a single plant would drown the root system and waterlog the plant. They didn't even go with a realistic number. 6 gallons is absurd, almost like they just arbitrarily pulled a number out of thin air. Which is what I suspect they did.
6 gallons a day would kill the plant. 6 gallons a day would kill most any small-med sized potted plant. This entire argument and discussion is ****ing retarded.
« Reply #69 on: Sat, 13 April 2019, 16:16:46 »
6 gallons IN A PlantPot would drown a plant.
NOT in a field, 6 gallon might not even be enough in a field..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #70 on: Sat, 13 April 2019, 16:26:34 »
Obviously the amount of water needed would vary based on whether the farming area orientation is vertical or horizontal, lighting equipment or sun exposure, soil drainage, etc..
  • Live long and prosper
« Reply #71 on: Tue, 16 April 2019, 18:21:40 »
I've been drinking every night for a while now. Either gin and tonics or just straight gin. Just enough to get me there and then I go to bed.
? Depression coping ?
anxiety coping, and when I was on disability for three months I kinda developed a drinking habit
tp thread is tp thread
« Reply #72 on: Tue, 16 April 2019, 18:34:42 »
At least -Not Meth_
« Reply #73 on: Tue, 16 April 2019, 18:35:23 »
At least -Not Meth_
never meth
only medical meth (amphetamines)
« Reply #74 on: Tue, 16 April 2019, 18:42:37 »
never meth
Slow release,  similar long term outcome, dependence, complete inattentiveness absent medi-meth.
« Reply #75 on: Tue, 16 April 2019, 20:27:56 »
Drinking Hurricane's and eating Top Ramen tonight like I'm 22 again. It's a bit nostalgic, but my pallet's become refined and these flavors are rough. That's fine, it'll all be a blur after the second Hurricane.
« Reply #76 on: Tue, 16 April 2019, 20:38:18 »
At least you don't drink Mad Dog 20/20
217436-0
« Reply #77 on: Tue, 16 April 2019, 20:40:35 »
oh man, you ever heard of Thunderbird or Night Train Express? Those are THE BOTTOM of the bum wine barrel. So bad, I challenge anyone to down a bottle.
these guys right here, they are the worst
« Last Edit: Tue, 16 April 2019, 20:42:23 by noisyturtle »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #78 on: Tue, 16 April 2019, 23:10:50 »
There's just not enough alcohol in MD 20/20 to make the taste ok
