Author Topic: Sweating Temperature ?  (Read 7192 times)
« on: Sun, 19 May 2019, 17:04:42 »
Getn' Warm up n' here finally.
What temperature do y'all begin sweating ?
Tp4 will begin to break a sweat @
Cloths on, ~85 F (29.4 C)
Shorts+ Tshirt, ~ 91 F (32.8 C)
High-humidity, ~75-80 F (26.7C )
Offline Lanrefni
Re: Sweating Temperature ?
« Reply #1 on: Sun, 19 May 2019, 17:17:35 »
72F or higher.
  • Live long and prosper
« Reply #2 on: Sun, 19 May 2019, 17:41:29 »
this is a very open question that depends on your level of physical activity
which is probably why TP can withstand such high temperatures before sweating
tp thread is tp thread
« Reply #3 on: Sun, 19 May 2019, 17:42:39 »
Different parts of my body sweat at different temps. My balls, ass, and hands start sweating at just above freezing. Rest of my body at like 80.
« Reply #4 on: Sun, 19 May 2019, 18:34:31 »
I napped on the couch earlier for a few hours with some mexican blankets on and the thermostat says it is 75 inside, I had to change shirts after because I was soaked in sweat. Did have headphones on also.
Offline natAT
« Reply #5 on: Mon, 20 May 2019, 00:24:57 »
I'm a girl. I never sweat (temperature regardless) and always smell like roses.
Except when I'm lying. Which means I'm sweating now.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Mon, 20 May 2019, 01:01:48 »
Pretty quickly. I overheat at almost any temperature. I blame ultra-slow metabolism.
Offline SBJ
  • Tactile pls
« Reply #7 on: Mon, 20 May 2019, 01:13:37 »
Doesn't take as much as it used to, to make me sweat.
I don't have specific degree numbers like TP.
But I'll say that after 21 degrees C it stops being fun for me.
Offline Coreda
« Reply #8 on: Mon, 20 May 2019, 01:42:58 »
East Asians have the advantage in this regard, since they sweat less and are said to have little to no BO depending on the region, due to the same gene that affects whether someone has dry or moist ear wax.
Offline p_blaze
« Reply #9 on: Mon, 20 May 2019, 09:51:58 »
lucky bastards
brown asian here takes about 85-90 for me to sweat but the slightest hint of psychological stress will turn my armpits into niagara falls even with antiperspirant
« Reply #10 on: Mon, 20 May 2019, 10:02:17 »
Are you the veggie brown asian, or the omnivorous brown asian.
« Reply #11 on: Mon, 20 May 2019, 18:01:13 »
Top temp was 53 today  :'(
Where's this Summer everyone keeps mentioning?
« Reply #12 on: Mon, 20 May 2019, 18:17:39 »
75F / 24C indoors
82F / 28C outside
I don't know why, possibly the "air film evaporation" effect.
- D Trump 2026-10-24
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Mon, 20 May 2019, 20:55:52 »
Normal clothes:                                                      90f/32c (a bit but not visible)
Normal clothes:                                                      95f/35c (visible--brow, etc.)
Shorts/flip-flops or barefoot:                                  95f/35c (a bit but not visible)
Job interview:                                                          70f/21c (visible--brow, hands, etc.)
When someone asks me to hold their baby:            50f/10c (instantly drenched)
Though I've been attuned to the heat in some unusual ways beyond the average Floridian, I haven't tested this in a while, but this is how I was in my mid/late 20s.
My reply is regarding outdoor temperatures.  I hope this is a satisfactory answer.
Offline ArchDill
« Reply #14 on: Mon, 20 May 2019, 21:34:18 »
Oklahoma has such high humidity that I sweat easily. I liked when I use to have to travel to New Mexico for work. It is a different kind of heat. The humidity is not as bad so it could be 95 outside and I would not sweat.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #15 on: Wed, 22 May 2019, 12:05:39 »
I begin sweating even if it's cold!
But it is really humid in this classroom due to the space heater.
Just my thoughts
Offline p_blaze
« Reply #16 on: Sat, 25 May 2019, 01:23:52 »
both? raised veggie and started eating the good stuff later down the road
Offline Sintpinty
    • My Roblox Profile
« Reply #17 on: Sat, 25 May 2019, 15:04:31 »
I am lack of vitamin D canadian
Just my thoughts
Offline invariance
  • ...here with all the other boson's
« Reply #18 on: Sat, 25 May 2019, 17:40:43 »
Down here the sun turns vitamin D into Basel Cell Carcinoma  >:(
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #19 on: Sat, 25 May 2019, 18:00:23 »
It was in the 40s today (8.8°C for you weirdos)
Offline invariance
« Reply #20 on: Sat, 25 May 2019, 19:28:28 »
That’s freezing 🥶.
No sweats from that.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
« Reply #21 on: Sat, 25 May 2019, 20:12:47 »
Fah scale is typically represented with more granular resolution.
Offline Sintpinty
    • My Roblox Profile
« Reply #22 on: Sun, 26 May 2019, 06:36:28 »
Ok that's fine, i have a coat
Just my thoughts
Offline chyros
  • a.k.a. Thomas
« Reply #23 on: Sun, 26 May 2019, 12:22:29 »
That’s freezing 🥶.
Incorrect. That's t-shirt weather.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #24 on: Sun, 26 May 2019, 12:32:29 »
That’s freezing 🥶.
Meanwhile people over here wearing sweatshirt layers, two pairs of socks, long johns, etc. for anything below 50f/10c.  Still shivering too. :p
Offline Sintpinty
    • My Roblox Profile
« Reply #25 on: Sun, 26 May 2019, 12:49:39 »
That’s freezing 🥶.
No longer shivering. There's been a lot of sunlight and it's gotten pretty hot outside.
Time to jump into the pool and start swimming  :cool:
Just my thoughts
« Reply #26 on: Sun, 26 May 2019, 13:31:51 »
Isn't it funny how "X" temperature might feel bitterly cold in the summer, but perfectly pleasant in the winter, and vice versa.
My air conditioning today, running hard during a heat wave in Atlanta, is producing a barely comfortable indoor temperature that would be smothering me in January.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #27 on: Sun, 26 May 2019, 15:39:51 »
Seriously though this is so true, depending on what I'm doing at work there are times I'll be sweating like a pig in sub 60 F temps.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #28 on: Sun, 26 May 2019, 16:10:02 »
99f/37.2c atm, but humidity is only ~40% woot
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #29 on: Tue, 28 May 2019, 13:39:36 »
Humidity is the only thing that gets me.
Offline phinix
« Reply #30 on: Tue, 28 May 2019, 14:52:51 »
Outside, when its sunny, clothes on - myself at around 18C.
« Reply #31 on: Wed, 05 June 2019, 22:11:45 »
Us weirdos are in the majority!
220577-0
Offline invariance
« Reply #32 on: Fri, 07 June 2019, 04:48:02 »
Is clothes on a variable or a constant?
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
Offline fanpeople
« Reply #33 on: Fri, 07 June 2019, 05:27:16 »
All measurements should be taken without clothes as the clothes themselves will create a variable simply by not being the same.
Offline Sintpinty
    • My Roblox Profile
« Reply #34 on: Fri, 07 June 2019, 09:21:44 »
Whenever it feels humid out i have energy.
Just my thoughts
