Author Topic: Razerons???  (Read 3360 times)
Offline xico_linguada
Razerons???
« on: Mon, 20 May 2019, 13:15:33 »
I dont know if this has been done before. I think i found a way to use the razer switches made by khail. Just swap the housing and spring from gateron yelows and i got a very smoth clicky switch. If you have some to spare, give it a try.
Offline Sup
Re: Razerons???
« Reply #1 on: Mon, 20 May 2019, 17:14:13 »
I tried this 2 years ago it's meh nothing special.
current
Coming soon
Re: Razerons???
« Reply #3 on: Mon, 20 May 2019, 18:35:31 »
You should try them side by side against Gateron Blue switches.
My guess is that you wouldn't find any reason not to get Gateron Blues in the first place.
« Last Edit: Mon, 20 May 2019, 18:37:29 by Findecanor »
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Razerons???
« Reply #4 on: Tue, 21 May 2019, 15:52:52 »
Razerons :cool:
Just my thoughts
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: Razerons???
« Reply #5 on: Thu, 23 May 2019, 07:54:50 »
This would be my guess as well.
Offline Clarence7747
Re: Razerons???
« Reply #6 on: Fri, 31 May 2019, 04:21:51 »
Offline mr.squishy
  • I like beer and keebs
Re: Razerons???
« Reply #7 on: Mon, 17 June 2019, 12:09:18 »
I actually have some "Chazors" in a cheap plank I built a few years ago. My reason? It was dirt cheap. I got like 50 razer switches for almost nothing here on GH a few years ago and swapped the stems into some unused Cherry housings. Marginally better, definitely a better sound. But most importantly it was cheap.
