Author Topic: What is your End Game switch?  (Read 2491 times)
Offline TeacherGeek
« on: Sun, 02 June 2019, 03:47:43 »
I've searched the forums for this topic but couldn't find it.
What is your favourite switch?
At the moment, they are Kailh Box Whites, but I am sure that will change once I play with more.
Offline lolafineday
Re: What is your End Game switch?
« Reply #1 on: Sun, 02 June 2019, 04:42:33 »
Right now they are gateron inks so smooth and such great sound
Sent from my SM-G975F using Tapatalk
« Reply #2 on: Sun, 02 June 2019, 07:22:24 »
Hall effect switches that have ANALOG,  + recalibration function as the magnetism changes overtime.
I would like to see optical do this as well, but leds are less stable than magnets unless they use an expensive drive system..
Other than that, MX-Blue is already mechanically perfect.
Offline natAT
« Reply #3 on: Sun, 02 June 2019, 08:28:30 »
Could never say for certain. From the wisdom of Yoda: "Difficult to see. Always in motion is the future."
It would very likely be based on a contactless sense means (Hall Effect etc). It generally seems like contactless sensing permits maximum flexibility in switch designs, for the most interesting and robust mechanisms.
Currently: The buckling springs in my (late) Unicomp are my favorite switch to date. So possibly the (reputedly superior) buckling springs of a Model F or a beamspring might quality as my "endgame".
Offline nelamvr6
« Reply #4 on: Sun, 02 June 2019, 08:30:42 »
Buckling Spring
Keychron Q6 w/ Zeal Clickiez | IBM Model F AT | Leopold FC660C | HHKB Type S
« Reply #5 on: Sun, 02 June 2019, 08:40:49 »
A super-smooth completely silent Cherry MX Clear with variable weighting.
I have wondered for some time if that could be realised as a modified Topre dome with helper spring. Dome for tactility. Helper spring with steep force curve for achieving cushioning after actuation.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #6 on: Sun, 02 June 2019, 09:01:27 »
Capacitive buckling spring, and modded box jade with a slightly stiffer spring.
Offline flurryvelvet
« Reply #7 on: Sun, 02 June 2019, 20:42:03 »
Alps SKCM Whites
Offline ArchDill
« Reply #8 on: Sun, 02 June 2019, 21:26:53 »
I like to change it up.. not sure that I could pick.
Right now... my favorite MX is 62g Vin blacks, lubed with 3204 in Zeal housings.
Offline thearctican
« Reply #9 on: Sun, 02 June 2019, 22:51:15 »
Topre 45g feel in an MX switch form factor.
