Author Topic: Linear switches - The search for the ultimate smoothness  (Read 21252 times)
Offline Prelim
« on: Wed, 14 August 2019, 05:44:06 »
Hi linear GH fellows!
vintage blacks VS retooled VS gaterons VS switch mods VS lube VS etc... what's your best achieved combo?
(please describe the switch and lube reference/mix used)
« Last Edit: Wed, 14 August 2019, 18:20:21 by Prelim »
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Surefoot
Re: Linear switches - The search for the ultimate smothness
« Reply #1 on: Wed, 14 August 2019, 07:03:47 »
So far Gateron Ink Black, lubed. Healios are very similar (with a slightly different sound). These both above Gat Yellow, Kailh Box Dark Yellow / Black, and again these above retooled Cherry Blacks.
Once lubed the difference is subtle to non existent (this excludes the Box switches of course). The Gat Ink Blacks start by being the smoothest.
Offline lolafineday
« Reply #2 on: Wed, 14 August 2019, 09:02:11 »
Just looking at smoothness tealios are the smoothest, but sound worse than inks
Sent from my SM-G975F using Tapatalk
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Wed, 14 August 2019, 09:11:14 »
Smoothest I've tried so far is Adomax Flaretech. Stock, even.
Forget about the ****ing lube. If you have to lube it, it's ****e :p .
Offline Zylkan
« Reply #4 on: Wed, 14 August 2019, 12:42:32 »
Forget about the ****ing lube. If you have to lube it, it's ****e .
doubt...
But then again, I've only tried cherry and gats. Lube makes a huge difference in both. And I'm not even using krytox
Offline GlennL42
« Reply #5 on: Wed, 14 August 2019, 13:28:29 »
Tealios and Adomax Flaretech are the smoothest switches I've tried so far and are very closely matched, based on my short comparison of both; at worst Flaretech is only slightly smoother than stock Tealios.
Tealios being a contact based switches yet still matching a contactless switches in itself is indicative of its smoothness really. Plus both have a similar feeling (edit: and sound) as well, probably due to the heavy usage of polycarbonate in their construction, though I could not scientifically back that statement.
« Last Edit: Thu, 15 August 2019, 06:57:21 by GlennL42 »
Offline Sup
« Reply #6 on: Wed, 14 August 2019, 13:31:21 »
Best linear combo i so far have tried is putting a Gateron Yellow stem and spring into a cherry housing with krytox. that sounded like heaven to type on with my Filco MJ2.
current
Coming soon
Offline Hyde
  • White Tofu Extraordinaire
Re: Linear switches - The search for the ultimate smoothness
« Reply #7 on: Wed, 14 August 2019, 20:07:35 »
To be honest smoothness was never an issue for me for linears.  Finding the perfect weight is hard.
I started with Cherry MX Red then eventually find it too light then tried MX Black and find it too hard.
I'm currently on Gateron Yellow and it's getting close but still a tiny bit too light, next up I might try Gateron Black.
Does anyone here have any experience regarding Cherry MX Nature White vs Gateron Black?
Offline Surefoot
« Reply #8 on: Thu, 15 August 2019, 02:57:30 »
I have both, the Nature Whites are closer to Blacks than Reds, but still a happy medium between them. Nature Whites are a bit scratchy due to the Cherry stem, i suppose one could swap a Gateron stem in there for smoothness.. Apart from that they are very pleasing in use but again im a Gat Ink / Tealios user so i might be biased.
Offline vafan
« Reply #9 on: Thu, 15 August 2019, 03:37:47 »
Tealios being a contact based switches yet still matching a contactless switches in itself is indicative of its smoothness really. Plus both have a similar feeling as well, probably due to the heavy usage of polycarbonate in their construction, though I could not scientifically back that statement.
Where do you buy Adomax Flaretech?
Offline Surefoot
« Reply #10 on: Thu, 15 August 2019, 04:17:49 »
Check out Chyros-san's videos from his signature.
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Thu, 15 August 2019, 04:23:43 »
doubt...
If you need lube, it's inherently a **** design, because lubricant will always have more friction than an inherently frictionless design.
Besides, let's be honest, a good switch shouldn't need so much work to make it good, if you can buy it brand-new. Factory-lubed switches deserve a bit more sympathy – but ultimately a contact-based design will never be able to compete with a GOOD contactless design in terms of smoothness.
Offline GlennL42
« Reply #12 on: Thu, 15 August 2019, 06:56:49 »
Sorry for poor choice of wording, I didn't own any loose switches, I tested an Aorus board with Flaretech switch in a mall and made comparison between both from memory; The only source for loose Flaretech switches as of now is from Wooting themselves AFAIK
« Last Edit: Thu, 15 August 2019, 08:07:50 by GlennL42 »
Offline Zylkan
« Reply #13 on: Thu, 15 August 2019, 08:45:06 »
doubt...
That makes sense. And again, I'm not really in a position to argue with you on that.
And I bet you made a lot of people curious on those switches.
Would be nice if someone else could chime in
Offline equalunique
« Reply #14 on: Thu, 15 August 2019, 11:30:13 »
Geekmaker purple linears are very smooth and generously pre-lubed out of the box
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #15 on: Fri, 16 August 2019, 08:19:59 »
Let us discuss linear switches.
I am here. Modern cherry mx blacks are awful.
Just my thoughts
Offline walie
« Reply #16 on: Fri, 16 August 2019, 08:56:22 »
In what way? What other switches have you tried?
Offline rxc92
« Reply #17 on: Fri, 16 August 2019, 10:17:38 »
I fully agree that MX Blacks are awful, and probably turned me off permanently to linear switches. I've tried all types of Topre, a few Boxes, modded Clears, all default Cherry switches, and the only one I dislike typing on are those and MX Greens.
Offline Riverman
« Reply #18 on: Fri, 16 August 2019, 12:12:03 »
One of these days I need to try regular MX black switches.  I recently bought a Cherry G80-3494 with silent blacks with the intention of swapping out the switches with something else, but I actually like the silent blacks and plan on keeping the keyboard stock for now.  The only other linear switches I've tried are MX reds, which I hate with a passion.
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Fri, 16 August 2019, 13:50:49 »
It took a great linear switch to show me how good they can be. When I had only tried MX black and the like before, I hated them.
Offline Surefoot
« Reply #20 on: Sat, 17 August 2019, 05:04:20 »
How good are geekmaker switches compared to Tealios and Gat Inks ?
Offline Hyde
« Reply #21 on: Sun, 18 August 2019, 17:46:43 »
lol ahhh ok I should look into those then.  Thanks!
Offline killyou
« Reply #22 on: Mon, 19 August 2019, 08:43:28 »
I'm tired with chasing perfect switches. I sold Zealios v2 and Tealios v1 and now I'm using Kailh BOX Pink with lighter spring as a daily driver. Couldn't be happier. I ordered Kailh BOX Red and Brown to give them a go as they seem to be a sweet stop with the price and quality.
Offline Aerizu
  • Professional Lurker
« Reply #23 on: Mon, 19 August 2019, 08:46:39 »
Have you tried using custom spring weights? I like 63.5g on my Tealios :)
Offline phinix
« Reply #24 on: Sat, 31 August 2019, 16:11:17 »
Which linear switches would be best for SA keycaps?
Offline rxc92
« Reply #25 on: Sat, 31 August 2019, 18:20:21 »
Offline phinix
« Reply #26 on: Sat, 31 August 2019, 18:42:18 »
If you think it has nothing to do with it, you are wrong.
For example 45g MX red are too light for example for SA, those heavier caps feel better with heavier switches.
For example, I only used SA with MX reds, balcks and Tealios and think that tealios are a lot better than MX. maybe there is other switch that feel better than Tealios, i don't know.
I was wondering what people prefer that is why I asked.
Offline Sintpinty
    • My Roblox Profile
« Reply #27 on: Sat, 31 August 2019, 19:45:20 »
MX reds deduct accuracy.
Just my thoughts
« Reply #28 on: Sun, 01 September 2019, 05:00:37 »
Cherry MX BLUE  is the smoothest switch BY FAR.
The primary reason for this is because the bulk of the slide-Action is between the nylon white click slider and the very loose blue round center stem. This produces far less friction than Red/ Black sliders where the spring leaf is always in contact with the stem.
Press an MX blue switch very slowly, it's smooth and light all the way down.
Press an MX Red/Black switch slowly, it's grindy and fricative.
Offline chyros
  • a.k.a. Thomas
« Reply #29 on: Sun, 01 September 2019, 05:21:00 »
Cherry MX BLUE  is the smoothest Cherry MX switch BY FAR.
phix'd that phor you
