Author Topic: Poll: Do you use the left or right shift key?  (Read 10800 times)
Offline Tigarion
« on: Tue, 12 May 2020, 08:55:45 »
I 've decided to take a poll on this subject. Do you use the left or right shift key more often?
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Poll: Do you use the left or right shift key?
« Reply #1 on: Tue, 12 May 2020, 08:57:52 »
Both.
Offline SihTzu
« Reply #2 on: Tue, 12 May 2020, 09:04:09 »
Both - Depending on which character has to be written in capital.
« Reply #3 on: Tue, 12 May 2020, 09:05:24 »
I use both, but I use the left shift more because the right hand has more things to do.
Offline Maledicted
« Reply #4 on: Tue, 12 May 2020, 09:11:39 »
I use the right shift key. I almost never use the left one, although it would probably make more sense for me to do so.
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #5 on: Tue, 12 May 2020, 09:14:25 »
Left exclusively.
On both keyboards and typewriters.
Offline 4everJayWalking
« Reply #6 on: Tue, 12 May 2020, 09:31:48 »
Both.
Offline Lanrefni
« Reply #7 on: Tue, 12 May 2020, 09:41:33 »
Both.
« Reply #8 on: Tue, 12 May 2020, 09:49:28 »
On a Split keyboard, you'd use both,  on a Standard qwerty board you'd only use the LEFT shift,  Rightshift is too far away to be efficient.
Offline Maledicted
« Reply #9 on: Tue, 12 May 2020, 10:00:09 »
I haven't even thought of it that way. My fingers are pretty long, so distance doesn't factor in too much beyond however tiny amount of difference in time there may be in reaching.
« Reply #10 on: Tue, 12 May 2020, 10:02:18 »
The longer your fingers, the further the right shift is away from that finger.
Offline Maledicted
« Reply #11 on: Tue, 12 May 2020, 10:09:34 »
From what position, and at what point of the finger? There's no difference in distance for the tip of the finger when resting on the home keys. With longer fingers, I can just reach further without difficulty.
« Reply #12 on: Tue, 12 May 2020, 10:21:52 »
It does depend on the angle of attk.
In general it's far more efficient to appropriate either the  ; key or / key for right shift if you must use it.
« Reply #13 on: Tue, 12 May 2020, 10:27:29 »
Both, probably right somewhat more often for capitalizing letters, but left much more often for Control-Shift or Control-Shift-Alt type combinations.
- D Trump 2026-10-24
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #14 on: Tue, 12 May 2020, 10:59:20 »
I use caps lock instead
Just my thoughts
Offline Tigarion
« Reply #15 on: Tue, 12 May 2020, 13:39:50 »
Thank you all for your responses!
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #17 on: Tue, 12 May 2020, 14:00:49 »
Both — as one is supposed to when touch-typing.
« Reply #18 on: Tue, 12 May 2020, 15:10:44 »
I literally never use the right shift
Offline Bruek
« Reply #19 on: Tue, 12 May 2020, 19:40:57 »
i don't use any right modifiers.
cronch
Offline captain
« Reply #21 on: Wed, 13 May 2020, 07:40:54 »
Mavis Beacon would be proud.
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
« Reply #22 on: Wed, 13 May 2020, 07:45:42 »
Mavis Beacon = Basic + Wrong.
They've been ruining proper typing since forever.
Wrong fingering, wrong theory, wrong emphasis of practice text.
Offline captain
« Reply #23 on: Wed, 13 May 2020, 07:59:32 »
To be fair, I never actually used Mavis, but I sold plenty of her. I learned to type, long before she came along, from a true typing teacher.  I’m sure I’ve perverted much of my teaching with my own preferences, by now. I think I’m also below 100wpm at this point.
But I’ve wondered about the “which shift key“ question many times, and usually conclude that I use both.
« Reply #24 on: Wed, 13 May 2020, 08:16:28 »
The LIES.. !!!!
Offline Darthbaggins
  • PC Cannibal
« Reply #25 on: Wed, 13 May 2020, 08:21:26 »
I favor the left due to gaming habits.
Offline iri
« Reply #26 on: Wed, 13 May 2020, 14:12:45 »
Both.
-Ray Bradbury
Offline funkmon
« Reply #27 on: Wed, 13 May 2020, 17:24:12 »
I only use the right.
« Reply #29 on: Wed, 13 May 2020, 17:47:20 »
Since a reasonable follow-up question would be about keyboard layouts and styles of shift keys, I will say that I have analyzed my shift key use (in previous shift threads here), and recognized how my fingers tend to work. (Note that I use conventional ANSI almost exclusively.)
I tend to strike the outside edges of the shift keys. For that reason, a short/split Left Shift does not particularly bother me since shift is to the outside, but a short/split Right Shift with shift on the inside drives me crazy.
« Reply #30 on: Wed, 13 May 2020, 17:47:34 »
left exclusively because gaming habits but you should be using both depending on the letter for max efficiency, moreso the right shift if you're typing in english with QWERTY
Offline depletedvespene
    • Keyboard-related resources.
« Reply #31 on: Wed, 13 May 2020, 17:59:15 »
Get a Brazilian Model M (or brazilianize a common one) and enjoy the goodness of an extra alpha.  :thumb:
Offline Shiraori
« Reply #32 on: Wed, 13 May 2020, 20:01:18 »
I use the left.
Kuro Shiro here we go!
« Reply #33 on: Wed, 13 May 2020, 20:09:12 »
this has to be a lie
Offline Sniping
« Reply #35 on: Thu, 14 May 2020, 02:20:54 »
left exclusively, even on split keyboards. just grew up learning that way. when i was a kid my hands were too small to comfortably right shift and type fast so i would always use left. my pinky still can't comfortably reach right shift imo
« Reply #36 on: Thu, 14 May 2020, 05:07:58 »
Well on Split, it's actually quite convenient to use both.  ONLY on qwerty, left is better.
Offline funkmon
« Reply #37 on: Thu, 14 May 2020, 09:45:10 »
No it's real! Haha. I type with like 4 fingers doing a giver hand and my left hand has my pinky up by the tab key. My right hand always has it near the shift. I literally don't think I have ever used the left shift. Sincerely.
Offline Maledicted
« Reply #38 on: Thu, 14 May 2020, 09:53:49 »
In normal typing, I don't use the left shift at all either. I can't imagine keeping my pinky up on tab though. I'm normally on the home row.
All I really use left shift for is hotkeys and gaming.
  • PC Cannibal
« Reply #39 on: Thu, 14 May 2020, 15:16:52 »
Also I dont use the right mainly due to it being mapped as Up Arrow on my main keeb.
Offline yui
« Reply #40 on: Fri, 15 May 2020, 00:27:56 »
depends, on iso i use both, on ansi i only use left because the enter key is too close in size and placement and i keep on pressing it instead. maybe it is because i learnt on iso keyboard and ansi is pretty new to me.
Offline funkmon
« Reply #41 on: Fri, 15 May 2020, 18:57:49 »
I'm actually going to record a video of my typing right now so you guys can see, but I need a reason to hit the shift key. NASA. Holy cow. Multiple sentences.
That's the text I just typed in this video.
Offline Boy_314
« Reply #42 on: Fri, 15 May 2020, 19:00:53 »
« Last Edit: Mon, 04 August 2025, 02:21:37 by Boy_314 »
Offline IronCheeks
« Reply #43 on: Fri, 15 May 2020, 22:47:09 »
Mostly left-shift since I am a gamer, but I am learning how to type using both of the left and right shift for when I type. Overall, just learning how to touch-type properly.
It's tough since it's been hard-programmed in my mind to just go for left shift, both in games and in typing.
  • Live long and prosper
« Reply #44 on: Sat, 16 May 2020, 05:23:46 »
Both...
tp thread is tp thread
Offline seville57
« Reply #45 on: Tue, 26 May 2020, 03:02:31 »
Both.
