Author Topic: It's Here. !! new keeb.  (Read 4834 times)
Re: It's Here. !! new keeb.
« Reply #1 on: Thu, 14 May 2020, 13:37:43 »
Pretty low volume even @ max... hrrrm... somewhat disappoint...... 22watt speakers my butt..
Offline dgneo
  • Supervillain
« Reply #2 on: Thu, 14 May 2020, 13:52:01 »
doesn't look very ergonomic - when u gonna turn it into a pianodox?
« Reply #3 on: Thu, 14 May 2020, 13:58:24 »
I'mma buy a second one after the pandemic, then Tent them @ 55 Degrees.
Offline yui
« Reply #4 on: Thu, 14 May 2020, 14:25:27 »
reading the title i was shocked that tp could be on topic, but i was reassured pretty fast, tp has not gone mad :)
« Reply #5 on: Thu, 14 May 2020, 15:09:01 »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Thu, 14 May 2020, 15:49:55 »
tp is not into keyboards.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #7 on: Thu, 14 May 2020, 16:19:31 »
Looks good :cool:
« Reply #8 on: Thu, 14 May 2020, 18:23:24 »
I've not looked at this type of keyboard in a long time but this one looks really wide.  Maybe it's just skewed perception as it's new so doesn't have much casing behind the keys...
Does 135wpm translate into musical talent?
« Reply #9 on: Thu, 14 May 2020, 19:12:46 »
It's like the second cheapest 1 on amazon. that's why it no haz all them kewl Thicc buttons.
The big panel kind are more pseudo control consoles for music production.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #10 on: Thu, 14 May 2020, 19:29:38 »
31 Lbs
I got 200 bucks for my birthday
I will spend it on another keyboard
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #11 on: Thu, 14 May 2020, 19:30:33 »
Depending on the beat yes but mine 141 wpm pb doesn't even sound like music
Just my thoughts
Offline Leslieann
« Reply #12 on: Thu, 14 May 2020, 22:24:27 »
22 watts is the total system power, not speaker power.
Power Consumption
    8 W (3--22 W)
    8 W: Average power consumption while piano is played with volume at center position
    3 W: Power consumption immediately after power-up; nothing being played
    22 W: Rated power consumption
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #13 on: Fri, 15 May 2020, 23:57:25 »
I wasn't expecting much from the sound, buhhh... Hrrrrmmmmm..... If I have to buy speakers, that would, increase the cost so much, I might as well buy a more expensive model ?
Offline ergonaut
« Reply #14 on: Wed, 20 May 2020, 01:31:05 »
You could just use headphones.
Offline yui
« Reply #15 on: Wed, 20 May 2020, 01:36:06 »
how would you impress the ladies if you are the only one hearing your masterpiece :)
« Reply #16 on: Wed, 20 May 2020, 06:45:18 »
Offline phinix
« Reply #17 on: Thu, 21 May 2020, 07:07:43 »
Cool, is it MX caps compatible? ;)
Now, we just need some video you playing some tunes!
