Author Topic: What did we learn Tp ?  (Read 3948 times)
« on: Mon, 25 May 2020, 12:29:11 »
nicht oelen  =  Do not oil
Do not oil things that says -Do not oil-
It was also stamped in english but on the other side of the wheel, so scheisse.
So, what now, DK. Can put it back together, but the probability of getting the winding right is almost 0.
243444-0
Re: What did we learn Tp ?
« Reply #1 on: Mon, 25 May 2020, 13:31:29 »
RTFM?
- D Trump 2026-10-24
Offline Leslieann
« Reply #2 on: Mon, 25 May 2020, 20:32:47 »
If it ain't broke, fix it anyway, then throw it away and go buy another.
My father and his father were great at that.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #3 on: Mon, 25 May 2020, 20:41:14 »
In Tp's defense, (it's ~20 yrs old) it were kinda broken, the spring has lost too much power over time..
Tp4 gently massaged the spring in the opposite curvature, but it's still not tension-ed right.
They probably have to drill and balance the thing based on spring variance. Sigh... These things are xpensive.
Buh,  plan B, now,  is  wind the spring in the opposite direction, Leave it there for oh, IDK a month for the spring to gather strength.  Then try again.
« Reply #4 on: Tue, 26 May 2020, 09:11:01 »
GDI, replacement springs are $20+
Offline yui
« Reply #5 on: Tue, 26 May 2020, 10:01:15 »
electronic metronomes/phone app are not an option? yeah those look nice but the alternatives are actually i think much easier to fix and gives you more options, if you do not manage to fix that one.
« Reply #6 on: Tue, 26 May 2020, 11:10:09 »
Ereybody put a dollar in the box..
243533-0
Offline yui
« Reply #7 on: Tue, 26 May 2020, 11:18:21 »
i was thinking if your fix does not work, as i am pretty sure an electronic metronome would be cheaper than 20$ and apps i would bet that there are quite a few free, phone or web
« Reply #8 on: Tue, 26 May 2020, 11:27:10 »
I understood yui, Tp4 were joking. A whole new metronome, <not made in germany> would only be $20-30
« Reply #9 on: Tue, 26 May 2020, 12:17:19 »
Tp4 thinks it might be the RUST causing the issue.
If y'all zoom in on the pictar, you can see there's some oxidation on the main and secondary shafts.
The main, has the most surface area in contact with the spring gear body.
Gonna try soaking in this evaporust, says safe on plastics, no solvents.
Offline 1391401
  • MX CLEAR
« Reply #10 on: Tue, 26 May 2020, 13:25:39 »
WHY would you oil that?  I would never oil that EVER.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
« Reply #11 on: Wed, 27 May 2020, 07:58:52 »
In the history of Tp4's stuffs,  Do not oil, has always mean't Oil-Tastefully.
So, the moral of the story is, Tp4 has learned Nothing, Tp4 was right all along.. The Germans done goofed using substandard steel...
The shaft has oxidized too much after (~20yrs), and has become just a little too thicc around the spring housing. This is the main section of power loss..
Overnighted in evaporust rust remover, and then a light polishing with mineral oil.
Runs gud' ,  Checking timing accuracy now.
Light coat: notice the minute shine.
243628-0
Offline Darthbaggins
  • PC Cannibal
« Reply #12 on: Wed, 27 May 2020, 08:52:02 »
Do not oil = Oil Liberally lol
