Author Topic: What years are considered "vintage" MX Blacks?  (Read 5283 times)
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
« on: Tue, 17 November 2020, 01:33:27 »
I came across some potential donors for older MX Black switches. I was just wondering what year is considered the cut-off for "vintage" Blacks. These are from 1994-1997.
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline Darthbaggins
  • PC Cannibal
Re: What years are considered "vintage" MX Blacks?
« Reply #1 on: Tue, 17 November 2020, 08:52:47 »
I think those are considered as a "Vintage" version, but I have seen some from back in the mid to late 80's as well which I would definitely consider Vintage.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Wed, 18 November 2020, 03:16:58 »
The dates and methods of identifying "vintage" cherry switches aren't really set (logo used to be the easiest tell, but people have found some not so great, newer-feeling big logo switches) but the dates you list are ehhh. MX browns weren't even introduced til '94, so vintage browns had to have existed at least that late, but most vintage blacks come from 80s and some early 90s boards. Then again, people have pulled great switches out of some mid/late '90s boards. While I'm sure it has lots to do with molds and material, I'm also sure that decades of use contribute as well so it's not really an exact science anyway.
« Last Edit: Wed, 18 November 2020, 03:25:08 by hwood34 »
« Reply #3 on: Thu, 19 November 2020, 20:16:26 »
I've done my own blind test, I couldn't tell vintage black from broken in modern blacks.
The additional smoothness also comes from the worn in Housing, not the stem.
Offline treeleaf64
    • treeleaf64
« Reply #4 on: Fri, 20 November 2020, 12:39:38 »
1983 - 1995
Just see if they are smooth or not
Doesnt matter about vintage or not vintage
Everyone must pay the cat tax
« Reply #5 on: Fri, 20 November 2020, 16:01:35 »
1983 - 1995
It matters only in the sense that, the Older it is,  The more Specialness you can brag about to your friends..  In the end, perhaps that's what this whole hobby is about,  who are we dressing up for ?
Offline rxc92
« Reply #6 on: Sun, 22 November 2020, 12:37:28 »
1983 - 1995
Tp, you can’t just say that vintage is the same as worn in. What if you hurt the feelings of the people who spent hundreds of bucks on their 40 year old switches? :p
« Reply #7 on: Sun, 22 November 2020, 13:15:21 »
Vintage will be special regardless of how they perform. They represent nexus points in keeb-excellence.
Tp is only saying that in terms of _smoothness performance_ ,  worn in housings (From any color switch new or old) are just as good.
