Author Topic: How do I achieve this sound?  (Read 3499 times)
Offline Jonnyswboy
« on: Thu, 19 November 2020, 09:19:40 »
Hello, I am new to the community and am looking for some advice.
I found this sound test and am trying to emulate it:
I very much like the deep muted sound.
I initially planned on using the Zambumon Sar as it has a thick 4.75mm brass (or PC option) plate and lubed Tealios much like the Zephyr in the video. But upon asking in some Discord servers I was told that I should get the PC plate option and black inks to achieve this sound. In the video he also replaced the tops with milky Gaterons and I am wondering how much that contributes to the sound. People also told me that Taeha modifies the sound in post for his sound tests.
Which plate and switch combo will get me closest to that sound test?
Thank you!
Re: How do I achieve this sound?
« Reply #1 on: Thu, 19 November 2020, 20:08:29 »
This guy types with a very shallow and light stroke.
pretty much every keyboard will sound like that with something soft under it, and typed on like a ****.
hahaha, just kidding, the way it's recorded can make a big difference too.
« Reply #2 on: Thu, 19 November 2020, 20:16:37 »
100% **** fingers ;)
Probably trained themselves not to bottom out on actuation, but really if you're not going full actuation you are only giving your keyboard just the tip. I prefer to go for full penetration.
« Reply #3 on: Thu, 19 November 2020, 20:19:08 »
This dude also wears rings ? LOL, watching too many korean boy bands maybe. from his whole setup he's taking that metro thing very seriously.
Offline Leslieann
« Reply #4 on: Thu, 19 November 2020, 22:34:01 »
Taeha's sound is not edited as far as I know and I have no reason to think it is, there is a lot of people with stock off-the-shelf keyboards who just don't know it can be that way.
As others mentioned, he does type very soft and puts something under the keyboard to isolate it from desk reverberation, but the sound is not unique.
Start with good switches good springs.
Bad springs make a lot more noise than you realize and once everything else is sorted, that is when they reveal themselves. Even cheap switches are pretty darn good with enough lube and good springs. Light springs ping worse than thick ones but Cherry light springs are especially known for ping. In my experience, Kailh Pro springs are bad as well. If you are into light springs (I use 39g) Mechanicalkeyboards.com and Sprit are the way to go. Coated springs tend to also be better.
Maybe lube your switches...
Notice I said enough lube, not every switch needs lube or benefits from it. A high end switch is probably going to be fine, but how would you feel if you spent all that time soldering switches in then find they need lube? Now you have to desolder (which is a pain and risky) and start again. This is why you see expensive switches being lubed, it's not that they necessarily need it, it's insurance. Even with good switches there's always the risk of a bad batch.
Lube and band aid mod your stabs,
This cannot be stressed enough on tactile and linear boards, you may even need to replace them but they can make or break a board once you know the difference. On a clickey board people tend to not care as much because it just adds to the click but on tactile or linear you hear everything.
Put foam in the bottom under the PCB if you can, some boards have no room, some come with it. Foam shelf liner (the plaid/checkerboard pattern stuff) works well and it's cheap.
Something important to note, I did NOT say start with expensive switches or an expensive keyboard or even an aluminum keyboard. I have a GMMK that sounds like a high end custom build. Why? Because I did what I mentioned above. It's insane how much difference those few things can make, but bear in mind, all the lube costs a bit of money and it's going to take some time to break down and properly lube those switches and stabs, especially if you start with a pre-built board that's soldered.
« Last Edit: Thu, 19 November 2020, 22:42:05 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Fri, 20 November 2020, 10:02:29 »
prettttty  certain his setup goes through a lowpass filter somewhere.
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Fri, 20 November 2020, 12:38:09 »
He has 5 deskmats
Please do not assume that your sound will be the same
The only substitute for getting exact same sound is hearing it in person
https://docs.google.com/spreadsheets/d/15XmznA5T9d4PkfBG0TDS82ou6ihBh0oqr8Aux24SNz0/edit#gid=805940844
See spreadsheet for what affects keyboard sound
Everyone must pay the cat tax
Offline Jonnyswboy
« Reply #7 on: Fri, 20 November 2020, 12:48:32 »
He has 5 deskmats
Thank you this is what I have been looking for.
Offline Darthbaggins
  • PC Cannibal
« Reply #8 on: Fri, 20 November 2020, 13:24:42 »
could just play that sound as you type, lol.  But your solutions have been previously mentioned by other users.
