Author Topic: Why aren't stabilizers and switches housings made out of PTFE  (Read 2670 times)
Offline zhnu
« on: Mon, 30 November 2020, 09:44:07 »
Hi, my question is with so many lube fans why no one is making stabilizers and switches housings out of PTFE or something similar.
Offline Leslieann
Re: Why aren't stabilizers and switches housings made out of PTFE
« Reply #1 on: Mon, 30 November 2020, 20:11:02 »
Stabs are there to stabilize keys so they need to be stiff enough to do so, PTFE is not a stiff or strong material.
Like PLA it also tends to adapt to whatever shape it's pushed into over time, so you wouldn't want it where the wires go because it would be too soft and you can't reliably use it on the base of the stabs because screw in would crush and distort and if they clip in they would eventually lose their grip and pull out. If they ever held in, being how slippery they are.
As for something similar, ABS, Polycarbonate and Nylon are used because of their slippery properties, basically the bext best thing. There's probably some newer or better plastics these days they could choose, but you also have to consider cost/benefit. If setup right they should have very little friction as it is so is it worth paying $100 for a 1% reduction in friction?
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline zhnu
« Reply #2 on: Tue, 01 December 2020, 10:59:27 »
I was thinking they could do like you see in electrical tools mouldings an kind of hybrid where you have fibre reinforced plastic, and I think for low volume production like custom switches we see on group buys, it would be awesome. Anyway thank you for the reply
