Author Topic: Any way to fix chipped coating on aluminium keyboard case?  (Read 10652 times)
Offline KeyRelic
    • KeyRelic
« on: Sun, 13 December 2020, 10:03:45 »
I use Ducky Shine 7 Blackout edition for around 2 years now and the coating on the aluminium case is starting to chip off pretty bad now.
Is there any way I could refurbish it myself? Anyone with experience in a similar situation?
Offline Sup
Re: Any way to fix chipped coating on aluminium keyboard case?
« Reply #1 on: Sun, 13 December 2020, 17:29:49 »
Let a company anodize it black again. You can do DIY but the equipment you need is expensive and if there is a scuffed way to do it it would probably not come out pretty.
current
Coming soon
Offline Leslieann
« Reply #2 on: Sun, 13 December 2020, 19:40:53 »
That's not anodizing, that's paint. Anodizing shouldn't chip.
Sand it down, prime it and paint it again.
Or send it out for power coat, ceracoat or anodizing. Expect any of these to run you around $100 or more to have done.
You can do all three at home, but you'll want to learn how on something a bit less complicated first and don't expect it to be all that much cheaper. Of the three, anodizing is by far the most difficult to get a good finish at home and the most complicated.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Sup
« Reply #3 on: Sun, 13 December 2020, 19:53:05 »
Now i look at it again yeah that makes more sense.
current
Coming soon
Offline Darthbaggins
  • PC Cannibal
« Reply #4 on: Mon, 14 December 2020, 09:04:31 »
A black sharpie should do  ^-^    ;D
« Reply #6 on: Mon, 14 December 2020, 11:12:56 »
When painting aluminium, it is important that the surface is freshly sanded and that you use a primer for aluminium. Raw aluminium oxidises in air within minutes, making it harder for the primer to stick, so it is important that it is done right away.
If it is a chip in black-anodised aluminium then you could blacken it with Birchwood-Casey Aluminum Black from a gun store. Dab it on using a Q-tip dipped in the stuff.
But in this case too, it must be done within minutes of the chipping, or it will not work. Unlike a sharpie, the liquid will not affect anodised aluminium - only the chipped raw aluminium.
Offline KeyRelic
    • KeyRelic
« Reply #7 on: Mon, 14 December 2020, 12:09:40 »
So this liquid won't work if the chipping is old and exposed to air for a long time now, correct?
What if I would clean the exposed aluminium part with alcohol or something else?
« Reply #8 on: Mon, 14 December 2020, 17:11:06 »
The easier way, is to just call it battle damage, and move on with ur life.  It's alot of hassle.
The odds that you manage to procure a female for your room, and she proceeds to not disrobe because you've got a chipped keyboard is Very-Unlikely.
Offline cheater
« Reply #9 on: Wed, 16 December 2020, 17:48:33 »
This might look pretty good with a coat of rubberizing
Offline Leslieann
« Reply #10 on: Wed, 16 December 2020, 21:15:21 »
My advice is just use a sharpie or some fingernail polish.
Will it match perfect, nope, but soon enough there will be more scratches anyhow.
Another option is to just sand the whole thing down for a satin look, or polish it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
