Author Topic: Take dat Vitamins  (Read 1785 times)
Take dat Vitamins
« on: Sat, 30 January 2021, 09:06:12 »
Dun' be like Tp who developed a vitamins (D) deficiency years back.
Now that ery1's homeLyfn'   make sure to take vitamin D and B12 (for immunity b00st).
If you have the regiment attitude, Absorption is more efficient when taking half the daily amount twice a day vs all at once, because in some cases the binding sites are exhausted and it is flushed through.
Offline Faceman76
Re: Take dat Vitamins
« Reply #1 on: Sat, 30 January 2021, 09:22:33 »
Exactly why I buy gummies that require two gummies per day and space them apart.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
« Reply #2 on: Sat, 30 January 2021, 09:53:12 »
It helps to visualize them as antidotes so you remember to take them.
You're on a quest and you've been poisoned.
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #3 on: Sat, 30 January 2021, 09:58:00 »
Good thing females won’t have to worry about Vitamin D deficiency.
