Author Topic: How To Sew Lined Curtains  (Read 4646 times)
Offline tylerjames
« on: Tue, 02 March 2021, 03:48:38 »
I know you are here because you do not want to sew a curtain that you can see through. Lined curtains have thick linings so it has a wide range of applications. Some of you might want to sew either drapery lining or interlining and some of you might want to add both. Whatever you want, the tips I share here will be of great help.
Before we dive into the tips, let’s talk about some of the lined curtain applications. You may discover something you do not know before in this article.
Keeping The Light Out
In some fancy hotels, you will see so thick curtains that they totally block the light out. The reason here is they want to make sure guests have asleep as long as they like. I do not know about you but I personally do not like to be woken up early when I am on a vacation.
Lined curtains
When you want to recreate this effect, make sure that you go for a synthetic material. However, not all home sewing machines can handle the thick material that is required to sew lined curtains. The needle and the stitches might be broken and the skipped stitches might happen. The solution here is to read best heavy-duty sewing machine reviews to find a competent model. To save you some time looking, read this article to choose the best heavy duty sewing machines.
These machines make use of larger and more durable needles and some of them might feature a built-in walking foot to sew multiple layers of thick fabrics. The walking foot will balance out the pressure that the feed dog applies on the project so that different layers do not go off course when you sew.
Keep The Room Warm
The interlining is what you should add to a curtain if you want to keep the cold off the room or the office. This layer comes between the main fabric and the other lining layer.
To fulfill this purpose, what you should look for is a loosely woven fabric as the interlining. Such material is the best in keeping the cold out of the room. The material has another benefit. It makes the final curtains look thicker.
Sometimes the color of the lining might contrast with the main curtain fabric so to ensure you have a good-looking final product, have a talk with a specialist for advice. I have seen a lot of curtains that the lining shows itself through the main fabric, making them look weird and wonky.
Keep The Room Free Of Noise
An interlining can block the cold out but you also want to block the noise, you might want to increase the thickness of this layer. This type of lining has an official name too. It is England-Bump, which is twice or even three times as thick as a regular interlining.
This is what bothers sewists a lot as it is thicker than what most home sewing machines can handle. A material to sew a normal curtain is thick enough, imagine double or triple this thickness and you will see why.
I know lined curtains sound intimidating to work with but there is a way to solve the problems. Here are some tips to help you:
If England-Bump curtains are what you want to sew (which has three layers, the main fabric, the lining, and the interlining), the needle you want to opt for should be of size 20 or 22. The machine should go with a walking foot. What I usually use is a 135x17 needle. It sews through the thick curtains easily. For a list of the best heavy duty machine for home use that allows these settings, read our guides at CraftsSelection website to find out.
Straight stitches work best on lined curtains. Just make sure that you backstitch properly at the beginning and the end to ensure the durability of the curtains.
Back-stitching at beginning and end of seam to secure
The thread I often use is the nylon bonded 69. However, depending on the material you use for the curtain, the lining, and the interlining, choose the type of thread accordingly. If you have no experience with this, call The Thread Exchange. Tell them about the make and model of your machine, the material you intend to use. They will recommend the type of thread that is suitable for your project.
When you are done, wash the curtains, dry them and if necessary, iron them thoroughly. You do not want your curtains to be wrinkled, do you?
You want to fold the hem twice to add durability to your curtains so make sure that you cut the width by 2 extra inches and the length 7 inches. This will allow you to make such hem.
While the main fabric should have extra fabric, you want the lining to be cut exactly as you plan. You want everything to fit so measure again when you finish cutting and trim off the exceeding if needed.
When you sew hems, make sure that the lining is tucked under and keep everything in place by using pins. This step can be skipped when you sew other projects but for lined curtains, always take time to pin to make sure everything stays in its place.
Unless you intend to make the thread pops, always use the thread that has the color matching that of the fabric. I have never tried using a different thread but I do not say that you cannot try.
This is the order you want to follow: first, sew the top hem; and then the side hems. Do not do differently because you will cause yourself the trouble.
Not all budget-friendly models can sew thick fabrics but there are some of them might. If you want to know about the top heavy duty sewing machines for beginners that can handle this job, visit our website CraftsSelection today. Check it out.
« Last Edit: Thu, 30 June 2022, 11:45:27 by tylerjames »
Offline yui
Re: Any suggested keyboard for gaming?
« Reply #1 on: Tue, 02 March 2021, 05:11:06 »
designer work require a lot of keyboard input? the ones i know pretty much use exclusively the mouse and a tiny bit the numpad so to me apart from meaning you want a layout with a numpad and maybe silent if you work in a silent office does not mean much, correct me if i am wrong.
do you need silence?
what do you like as key-feel go?
 - linear (the key weighting changes linearly with travel)
 - tactile (the weighting has a bump in the curve)
 - clicky ( the weight increase linearly and then has a sudden drop accompanied with a click often near the actuation point)
 Rubber domes often feel into the tactile category
a 200 dollars budget will allow for some rather nice prebuilt or some lower-end customs, what were your intentions?
and any preferred colors?
with those answer we could help you to get closer to your perfect board, right now it is a bit too wide to get any good advice
Offline yui
« Reply #3 on: Tue, 02 March 2021, 07:06:15 »
CHerrryy Mxx BLOOOOO
i dunno if there is much worse than blue for gaming, hysteresis and annoying everyone in teamspeak/discord/voicechat :) oh yeah there is the model M and F :)
« Reply #4 on: Tue, 02 March 2021, 07:07:18 »
That's how you Stance-Of-Dominance the Teamspeak server..  It's a competitive advantage
leadership +++,  goes on your collage application
Offline Darthbaggins
  • PC Cannibal
« Reply #5 on: Tue, 02 March 2021, 07:43:22 »
Box Navy or Jade is the Bloo's only rival (other than their forefather the beamspring).
I would try out a few boards if you can and see which switch and layout fits what you need.   I mainly use 60-75% layouts for gaming and in the Adobe Suite (PS, LR, and Illustrator) - for my workflow at work I tend to use a 96key since I use the numpad more often when I have to work in books in Excel and Access - but in the end depends on the type of design workflow you do.
Offline !Q
« Reply #6 on: Tue, 02 March 2021, 13:34:53 »
ginny heavy, max ergo means you can hit all the keys you need and never miss
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #7 on: Wed, 03 March 2021, 21:49:07 »
Just my thoughts
Offline Leslieann
« Reply #8 on: Thu, 04 March 2021, 19:50:58 »
Hi, as I mentioned above, I'm looking for a good keyboard to playing game and for my work as a designer. My budget is around $200.
Depends on the games you play,
I you primarily play FPS, look at linear and tactile, ignore clicky, if that's not your primary type of game go for whatever you like.
As for recommendations, you're a bit under budget for an all aluminum so I'd recommend the best quality you can get otherwise, typically that's Ducky, Leopold and Varmilo. If you want to really break into this as a hobby I'd also say GMMK. The others will likely be better at least initially and are great boards but the GMMK is a gateway drug, you can buy it barebones and it's hot swap allowing you easy access to tons of switches and mods. Another good option if you can live without RGB is WASD, start with the normal board then later add an aluminum chassis (TKL only I think) to it if you decide you want that. They also offer this without caps, but it's not hot swap.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline RotaryFist
« Reply #10 on: Fri, 05 March 2021, 00:14:17 »
Genovation KeyBoard KB170L  :p
