Author Topic: Any custom tkls?  (Read 2818 times)
Offline Error213
Any custom tkls?
« on: Sat, 13 March 2021, 23:39:09 »
I would prefer under 400$ under 300$ is great
Offline Leslieann
Re: Any custom tkls?
« Reply #1 on: Sun, 14 March 2021, 05:46:20 »
It's a bad time to buy and TKL is out of style at the moment.
Check Krepublic and KBDfans. If you want a more classically styled TKL WASD has a nice traditional TKL with aluminum case though it's not a kit.
Other options are Idobao (2 styles both available in hot swap or not) and the new GMMK Pro.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline pepperfez
« Reply #2 on: Sun, 14 March 2021, 22:01:27 »
Right now is actually a great time to find an inexpensive TKL kit. NovelKeys opened the preorder for their NK87, which has an aluminum case, hotswap sockets, and a frankly ludicrous amount of silicone damping for $265. I'm typing this on an NK65 and the quality and value are through the roof, so I would feel good betting on the TKL equivalent.
e: lol, I just realized that my gushing praise and 2 total posts make this look extra shillish. The NK65 is real good tho.
« Last Edit: Sun, 14 March 2021, 22:07:09 by pepperfez »
Offline Error213
« Reply #3 on: Mon, 15 March 2021, 22:57:53 »
is the nk87 a one time gb or is it like the nk65 where it restocks
Offline Leslieann
« Reply #4 on: Tue, 16 March 2021, 02:54:02 »
If you want one do the group buy or be prepared to spend the next year or more trying to get one.
The last NK65 shipment was gone in a few days (with aluminum edition gone long before that), in the shipment before that before that (which was limited) aluminum versions were gone in 3 minutes (I timed it). The KBDfans KBD67v2 was mostly gone in less than 24 hours.
Obtaining certain computer hardware right now is extremely difficult, CPUs, GPUs, SFX power supplies, webcams, and keyboards have been hit the hardest. And while some of those will and have started to ease (webcams in particular) some of these (GPU, CPU and keyboards) will have shortages for at least another year.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #5 on: Thu, 18 March 2021, 09:01:09 »
You want SPLIT , TKL is sooooo 2014
Offline bkrownd
« Reply #6 on: Thu, 18 March 2021, 17:12:14 »
  What exactly does "custom" mean to you?  Build-it-yourself?  Fancy chassis with brass slug and accent badge?  Blinkenlights chasing each other around like rabid kittens?
