Author Topic: Burrito Sizes  (Read 5674 times)
Burrito Sizes
« on: Mon, 19 April 2021, 09:15:29 »
How big do you guys make um.
Tp4 makes them Hotdog sized.
Empirical testing, Any bigger, the stuffing tends to fall out more easily, and you don't get enough of the salty wrap taste/texture per bite.
Offline glibber
Re: Burrito Sizes
« Reply #1 on: Mon, 19 April 2021, 09:37:55 »
I like 'em big
I like 'em chunky
Offline dingusxmcgee
Re: Burrito Sizes
« Reply #2 on: Mon, 19 April 2021, 09:43:02 »
I like to go to a place in town called “Fat Burrito” and get a 16”. Perfect size for two meals!
Re: Burrito Sizes
« Reply #3 on: Mon, 19 April 2021, 10:01:33 »
what's their circumference.
Offline yui
Re: Burrito Sizes
« Reply #4 on: Mon, 19 April 2021, 10:28:52 »
when i went to the kebab place i used to get their durum option, a kebab in a burrito form pretty much, and they were about 3 to 4 cm in diameter, depending on how big the salad was cut that day. at home i am usually a bit more conservative.
Offline Darthbaggins
  • PC Cannibal
Re: Burrito Sizes
« Reply #5 on: Mon, 19 April 2021, 10:32:56 »
I get mine put into a bowl rather than wrapped in a tortilla.
Re: Burrito Sizes
« Reply #6 on: Mon, 19 April 2021, 10:45:54 »
16” tortilla
Re: Burrito Sizes
« Reply #7 on: Mon, 19 April 2021, 10:51:34 »
I used to go to a Mexican place that sold burritos ("little donkeys") which were "regular" US size (like what Taco Bell sells) and then "burros" which were at least double the volume. I preferred them since they were a better value and had a better ratio of filling to carbohydrate.
They were difficult to eat, but since they came well wrapped in aluminum foil you could eat them by hand if you were careful to peel down the foil just so. And yes, they were often a 2-meal purchase. They could also be eaten easily enough on a plate with knife and fork because they did not make the filling too runny.
- Plato
Offline meatsmoothies
  • howdy!
    • portfolio / store
Re: Burrito Sizes
« Reply #8 on: Mon, 19 April 2021, 12:05:12 »
the place i live across from does burritos about 7" long and i wanna say 2" wide
Re: Burrito Sizes
« Reply #9 on: Mon, 19 April 2021, 12:07:56 »
16” tortilla
ok so 16" sheet, then the circumference of the completed roll =? :D
Re: Burrito Sizes
« Reply #10 on: Mon, 19 April 2021, 12:08:50 »
2" diameter is hotdog sized, very fit.
Re: Burrito Sizes
« Reply #11 on: Mon, 19 April 2021, 12:11:17 »
16” tortilla
I'll try and measure for you next time  :))
Re: Burrito Sizes
« Reply #12 on: Mon, 19 April 2021, 12:18:21 »
I try to get burritos around the diameter of my palm, that way when I hold the burrito's end it fits perfectly and I'm not afraid of anything falling out.
Re: Burrito Sizes
« Reply #13 on: Mon, 19 April 2021, 14:33:26 »
BIG like a small puppy wrapped in a blanket
none of this 2" pencil **** burrito bull****
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: Burrito Sizes
« Reply #14 on: Mon, 19 April 2021, 14:41:23 »
l = ~ 1,5 - 2dm
Ø = ~ 4,5 - 5cm
C = ~ 1,5 - 1,7dm
Mean density = Burrito
« Last Edit: Mon, 19 April 2021, 14:43:16 by Olumin »
Offline treeleaf64
    • treeleaf64
Re: Burrito Sizes
« Reply #15 on: Mon, 26 April 2021, 13:50:23 »
I love the burrito
Everyone must pay the cat tax
Re: Burrito Sizes
« Reply #16 on: Mon, 26 April 2021, 14:23:33 »
It's weird how Cali puts fries in their burritos and that's kinda the norm out there. Very California.
  • PC Cannibal
Re: Burrito Sizes
« Reply #17 on: Mon, 26 April 2021, 14:26:08 »
I mean, I don't see that as a bad thing - other than Fritos in a Burrito > Fries
