Author Topic: Thicc TKL recommendations?  (Read 2941 times)
Offline bearattack
« on: Wed, 28 April 2021, 19:07:36 »
I'm looking for a thicc and heavy TKL keyboard, something along the lines of a Rama U80-A. I'm pretty new to this world of high-end keyboards. Is there anything out there available or soon to be available? I'm ok with waiting for a GB for the right endgame keyboard.
Offline gh_pp
Re: Thicc TKL recommendations?
« Reply #1 on: Thu, 29 April 2021, 00:40:46 »
If you asked a month or two ago, this would be up your alley
https://kbdfans.com/collections/80-diy-kit/products/coming-soon-epoch-80-mechanical-keyboard
This thick keyboard has been in stock for a long time (because most people prefer thin bezel) and just recently sold out.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline bearattack
« Reply #2 on: Thu, 29 April 2021, 08:27:41 »
Thanks for the recommendation - that is right up my alley. Alas, it looks like my timing couldn't be worse. I'll keep an eye out for more GB or restocks but any other recommendations are welcome!
Offline Maledicted
« Reply #3 on: Thu, 29 April 2021, 09:53:08 »
I have a few of these Aliexpress cases. They're very thick and heavy, and are compatible with at least a few different TKL PCBs. I put Matias switch KBParadise V80s in mine.
Offline daja_nga_kavaja
« Reply #4 on: Fri, 30 April 2021, 15:23:43 »
Maybe "Orion V 2.5" https://geekhack.org/index.php?topic=109033.0  around 2.5 Kg.
And then you can add even more weights with brass bars
« Reply #5 on: Fri, 30 April 2021, 16:43:09 »
Thiccer caps usually means louder return stroke.
Offline Leslieann
« Reply #6 on: Fri, 30 April 2021, 18:36:20 »
Yes, but this can be mitigated various ways and thicker also means lower pitch, which tends to be considered more pleasant.
I will take a slight louder more pleasant sound than a quiet horrible sound, nothing sounds worse than cheap, thin PBT.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
