Author Topic: Are Orings still Kewl ?  (Read 2664 times)
« on: Mon, 10 May 2021, 19:37:58 »
These little opaque white ones on ebay NE good,  they soft , hard, ne1 try them ?
What's the Premo Oring these days ?
Offline yui
Re: Are Orings still Kewl ?
« Reply #1 on: Tue, 11 May 2021, 03:12:20 »
well since silent switches exists nowadays so o-rings became kinda useless, they impede the travel more and only silence the down stroke. although if you want silent blue you will have trouble finding them and may need to resort to o-rings :)
silent switches uses little rubber inserts either side of the slider to dampen the sound, works pretty well, to be honest i never had o-ringed switches so i can't really compare
Offline Leslieann
« Reply #2 on: Tue, 11 May 2021, 03:29:24 »
Depends on your goal and your caps.
On my caps if I use only one o-ring they won't even hit the housing, however they work great for adding mass to the caps and deepening the sound.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #3 on: Tue, 11 May 2021, 07:37:17 »
oh dang, which caps are these that won't contact.
« Reply #4 on: Tue, 11 May 2021, 09:58:35 »
Blue Gateron sliders will fit QMX clips though. Other blue switches have a small nub on the top of the slider (to the side of the keycap mount) that gets in the way, so that you'd have to resort to O-rings on those, yes.
« Last Edit: Wed, 12 May 2021, 00:28:19 by Findecanor »
Offline Leslieann
« Reply #5 on: Tue, 11 May 2021, 21:18:24 »
Not GMK
You want old SP and HK Gaming
On Jailhouse Blues I was even running dual o-rings with only some touching, depending on the row.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leopard223
« Reply #6 on: Thu, 13 May 2021, 17:46:21 »
How would you create a silent blue switch? I'd imagine you would have to dampen the part between the stem and the jacket since the bottoming of the jacket is what causing the click.
I'd love to use some dampened clickbar switches though, I havn't had the chance to use MX style clickbar switches, but the BOX ones bottom out is very harsh, you could definitly feel the difference in terms of sound and feel.
Offline yui
« Reply #7 on: Mon, 17 May 2021, 02:36:43 »
it was a joke, as TP only ever recommend MX blue as the ultimate switch to end them all, i was not serious.
