Author Topic: Best recording and editing software for music and voice?  (Read 5349 times)
« on: Fri, 28 May 2021, 13:59:29 »
I've been using Audacity to record voice clips and was just curious if anyone has another suggestion for any audio editing software?
Preferably one that's easy to edit clips together. What do you use?
Offline Leslieann
Re: Best recording and editing software for music and voice?
« Reply #1 on: Fri, 28 May 2021, 19:56:21 »
Anything much better than Audacity is going to be paid or OS specific which is probably why it's so popular.
GarageBand is a good alternative but it only works on Mac.
Abelton, Adobe Audition, Acid Pro and Logic Pro are popular but they cost a fair bit. Cakewalk used to be a good lower priced option on Windows but they were bought out and shut down.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
