Author Topic: Survey for market research class  (Read 3943 times)
Offline hippovelocity
« on: Wed, 16 June 2021, 20:10:23 »
Hi all, I hope it's okay to share this here but I'm looking to collect survey responses for a market research project. If you have a few minutes, please help fill out the survey. Thanks!
https://www.surveymonkey.com/r/HKM8MW3
Offline Altain
  • Formerly zungzangbi
Re: Survey for market research class
« Reply #1 on: Wed, 16 June 2021, 20:53:19 »
Done!
But I have a suggestion after completion - at Q.12 I had to choose an option from the provided Keyboard Designs, in which none of them I specifically prefer, regardless of what I typed in "Others" comment section.
I'd rather have "Other" not as a comment option but one of the choice options.
« Reply #2 on: Wed, 16 June 2021, 22:48:34 »
Question 7 is defective. It does not accept "Other" as an answer.
- D Trump 2026-10-24
« Reply #3 on: Thu, 17 June 2021, 06:58:21 »
All the questions are broken, It does not accept other.
« Reply #4 on: Thu, 17 June 2021, 07:55:07 »
The survey writer clearly has an extremely limited knowledge of keyboards and switches. Probably no experience with any vintage gear.
"Would you pay more if you could control the temperature?" WTF ? Is he talking about the color of lights?
« Reply #5 on: Thu, 17 June 2021, 09:31:50 »
I assume that meant something like a keyboard with a fan for sweat.  It could be useful, although in most cases speed and control wise, the hand needs to be warm, so it's better to be hot than cold.
Famous pianists soak their hands in hot water before performances.
Glenn Gould routinely seen with red hands, we assume he was a bit nutty and used very hot water.
Offline ElementalWheel
« Reply #6 on: Thu, 17 June 2021, 10:28:52 »
Poll filled, but like others commented the research is very basic, and some options just dont make sense...
« Reply #7 on: Thu, 17 June 2021, 16:05:06 »
Several questions are obviously broken.
"Which is your favourite material? PBT, ABS, Aluminium, Copper" For what?
"Which is you favourite actuation weight? < 40g, 80+, 110+ "..  Eh..
I'm sorry. Please do your research better beforehand!
Do limit your questions to those that you actually want answered!
« Last Edit: Thu, 17 June 2021, 16:09:07 by Findecanor »
