Author Topic: Basement Water  (Read 6093 times)
Basement Water
« on: Wed, 01 September 2021, 22:48:00 »
Tp4 water fighter, Narrowly avoided disaster.
Heavy water from Ida
For ~30 minutes,  ingress exceeded sump pump capacity.  It was still pumping, but the table was coming out the other end sets off flood alarm.
It's a good thing Tp4 kept buying those $50 Home depot/Lowes shopvacs on sale.
Filled up all six vacs. They're 12 gallons each. This would've easily cost more than $300 worth of water damage. holy crap these are heavy to carry upstairs.
100% Sure neighbors were screwed.
Sirens came to multiple houses across the cul-de-sac.
Does anyone know if there's a more automated system for this scenario ?
Tp4 understands he could get a bigger sump-pump, but that may not be the answer if bigger pumps won't fit in the hole.
For example, Tp could rig up a second pump piped slightly above the sump pump, but do they make a pump with a trigger / logic system that can be submerged along-side the original sump?
Tp4 could rig an arduino to do this, but they're not massively reliable and there's water involved.
Offline Faceman76
Re: Basement Water
« Reply #1 on: Wed, 01 September 2021, 23:39:48 »
Guessing you're in the Northeast, too?
It's still coming down hard here, roads are flooded and had several hurricane alerts to my phone.
Good times.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline Leslieann
Re: Basement Water
« Reply #2 on: Thu, 02 September 2021, 03:32:37 »
The best fix is to keep it away from the house to begin with,
Slope the ground away from your house.
Make sure rain gutters empty several feet from the house, an inspector may say something but builders don't seem to care. TONS of houses dump the rain gutters right at your foundation.
Get out during a rainstorm and verify this is working, paying attention to run off from your neighbors. We had to dig a trench through our yard to direct water runoff and it worked great until the new neighbors bumped a rain gutter drain pipe and was flooding the corridor between the two houses. It was a swamp when we found it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline fanpeople
Re: Basement Water
« Reply #3 on: Thu, 02 September 2021, 03:48:43 »
Break out the tarps and sandbags TP.... its sandbagging time.
Re: Basement Water
« Reply #4 on: Thu, 02 September 2021, 06:51:53 »
Straya xperiences ?
Also the price of sand lately iz ludicros
On edge, all last nite..
Offline fanpeople
Re: Basement Water
« Reply #5 on: Thu, 02 September 2021, 07:09:59 »
Straya xperiences ?
Yeah but our bags and sand are free from the local SES cuz they don't want to come out and sandbag themselves.
Re: Basement Water
« Reply #6 on: Thu, 02 September 2021, 07:10:34 »
Fighting nature is a losing proposition. Weather and gravity are more powerful than any human endeavor.
People have been moving water uphill for millennia, but it is never easy. There are ways to create 2-stage sumps and pumping systems, but they are neither cheap nor simple. Professional advice would be well worth the fee because every situation is different and maybe tricky, although a basement-waterproofing company would charge a fortune to do the complete job.
Buying sand in bags is hopeless, get a truck to dump a ton or 2 for the price of a few dozen bags.
- Franklin Roosevelt 1933
Re: Basement Water
« Reply #7 on: Thu, 02 September 2021, 10:23:14 »
/whatever the cost though,  seeeeems.... cheaper than basement flooding.
Offline Faceman76
Re: Basement Water
« Reply #8 on: Thu, 02 September 2021, 11:26:12 »
Dry wells for gutters and consider re-grating around your foundation.
Re: Basement Water
« Reply #9 on: Thu, 02 September 2021, 12:55:52 »
t00k a walk round the neighborhood,
Several houses had pump trucks parked in front of them.   Sump pump failures.
Check ur pumps guys... And have a backup pump ..
Offline Leslieann
Re: Basement Water
« Reply #10 on: Thu, 02 September 2021, 23:13:43 »
Some time with a shovel and gravity is free and despite the numerous times I've tested it gravity's never once failed.
The sump pump is supposed to be your backup/last hope, gravity and proper runoff is supposed to be your primary system, it can't keep your basement dry, only pump out excess. Expecting your pump to keep your basement dry is a good way to get infested with mold.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Darthbaggins
  • PC Cannibal
Re: Basement Water
« Reply #11 on: Fri, 03 September 2021, 06:17:16 »
Yup, you need to check your natural drainage since the pump, as you found out, can't fully keep up.  I know we had a house that was a challenge to fix the drainage issues due to the angle of the driveway causing massive rainwater right through the garage, and the drain at the bottom of the driveway was poorly designed from the previous owner (they installed the drain at an uphill angle).  We ended up having a French Drain installed and redoing the drainage from the driveway - as it ended up ending any issues we had in the basement/garage areas.
