Author Topic: Tap or Bottled ?  (Read 4071 times)
Tap or Bottled ?
« on: Tue, 21 September 2021, 18:14:50 »
So.... they be like, yo Tp4, bottled water's got _Leeching_ of petro-chemicals.
But if you look at civil engineering water (mains) pipes, they're metal, BUT, with a plastic inner liner.
Thoughts ?
Offline Shapey Fiend
Re: Tap or Bottled ?
« Reply #1 on: Tue, 21 September 2021, 18:23:23 »
The tap water quality is pretty good where I am so I'm fine with that.
To be honest I very rarely drink water anyway I just have a few mugs of tea a day.
« Reply #2 on: Tue, 21 September 2021, 18:23:53 »
Plastic creates waste and costs money, but tap tastes like ****.
The age old conundrum.
I've always wanted to get one of those big fancy countertop purifiers they have in water stores, but then you are buying expensive filter sets every few months for a unit that already costs $500
« Reply #3 on: Tue, 21 September 2021, 18:37:30 »
I live in a hard water area so it tastes good I guess? Water tastes like water to me.
Now if I'm on holiday in Singapore or something I ain't drinking the tap water. If it's been through 6 or 7 peoples bodies already I'll take my chances with the microplastics, which are probably already in the tap water anyway.
Offline Faceman76
« Reply #4 on: Tue, 21 September 2021, 19:25:29 »
I have a filter on my tap that makes the water taste okay.  At work we have a fancy reverse osmosis filtration system with a built in heater(perfect for tea or coffee press).  I've been meaning to pick up an under the counter reverse osmosis setup for home and will get to it eventually.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #5 on: Wed, 22 September 2021, 05:39:48 »
only ever drink mineral water from glas bottles. I also use it to make tea. no tap water, no plastic bottles.
Offline foxieze
  • i like code.
« Reply #6 on: Tue, 28 September 2021, 03:00:53 »
tap water is best.
« Reply #7 on: Tue, 28 September 2021, 06:34:40 »
I've been reading, they don't wash these bottles all that well.
Offline Tastenplatte
« Reply #8 on: Sun, 10 October 2021, 10:05:47 »
Does that even make sense? Wouldnt a water plant clean it to almost pure again anyway?
Offline Leslieann
« Reply #9 on: Sun, 10 October 2021, 22:43:01 »
You'd be surprised how much municiple water is still run through lead pipes.
Lead pipes are actually fine, depending on the water.
With the right water it will coat the lead with a protective layer (like oxidizing aluminum) and keep the lead from leaching into the water. The problem, and is what happened in Flint, was they switched the water supply and the newer water stripped that protective coating that had built up over the decades.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Go Gurt Stick
« Reply #10 on: Tue, 12 October 2021, 09:09:38 »
I have a reverse osmosis filter thing in my basement which I use for my water. It makes the water taste better than regular tap water, but that tap water in my area is said to be good and doesn't taste all that bad.
« Reply #11 on: Tue, 12 October 2021, 09:28:24 »
Lead actually tastes Sweet
« Reply #12 on: Wed, 13 October 2021, 07:54:27 »
I think my water should be fine then. I haven't noticed any sweetness in the water, tap or filtered, and I never knew that lead tasted sweet.
When I mentioned that the filter makes the water taste better than regular tap water, I meant that it tastes a little blander, as in it has a cleaner taste. I don't notice any odor coming from it as well.
« Reply #13 on: Wed, 13 October 2021, 08:18:16 »
People like to forget that tap water in the US has chlorine in roughly the same proportion as the water in swimming pools.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #14 on: Wed, 13 October 2021, 14:18:27 »
Water bottles CAN leach into your water; this is why bottled water has a best-before date. However, it only affects taste, and isn't significantly dangerous.
Over here tap water is the same, if not cleaner than bottled water anyway. It's a demo lab experiment we do at our university ^^ .
