Author Topic: Difference between GB and Preorder?  (Read 3720 times)
Offline granola bar enthusiast
« on: Sun, 24 April 2022, 20:49:18 »
Is there really a difference between the two? I have been wondering since I got into the community. Thanks!
Offline HungerMechanic
Re: Difference between GB and Preorder?
« Reply #1 on: Sun, 24 April 2022, 21:18:20 »
I think so.
GB is when you are in from the very start. As it is being launched and funded, with the full production time [other than IC] in front of you.
Pre-order is when the keycaps are already produced, but have not yet arrived at the distributor(s)/vendor(s).
For example, there was a GB for JTK Griseann / Royal Alpha back in 2021(?). You could get in at that point.
Later, in January 2022 or so, some vendors began allowing pre-orders for the sets. If you weren't in at the GB, you could still get in at that point, but at a higher price.
Basically, the cost to the buyer escalates from GB > pre-order > extras > aftermarket. Usually.
« Reply #2 on: Sun, 24 April 2022, 22:24:28 »
It's like A vs C bonds.
Preorder is usually an investment,
GBs are speculative.
Then you fill the gap inbetween based on known members, etc.
Offline AlphaStudios
  • Formerly Vlasta
    • Alpha Studios
« Reply #3 on: Thu, 28 April 2022, 14:05:30 »
The end result is the same no? You get what you want to pay for in advance.
Offline Leslieann
« Reply #4 on: Thu, 28 April 2022, 21:52:11 »
Groupbuy is crowd funding, same as Kickstarter and really SHOULD be treated as such.
Pre-order is a part already designed (and sourced), hopefully by a fully operational company, otherwise it's just crowd funding under a different name.
Groupbuy is very sketch, it's an investment in a (usually) unknown entity, if it fails you lose your money with little to no recourse.
Preorder is only sketch if it's a new company or a company on the brink of going under. Odds are if it doesn't happen you get a refund.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
  • Formerly Vlasta
    • Alpha Studios
« Reply #5 on: Fri, 29 April 2022, 08:51:51 »
Righttttt - I had not realised that GB was the sketchy verion. I thought and hoped that people would refund the money of the GB failed. I live and larns.
« Reply #6 on: Fri, 29 April 2022, 09:46:04 »
//gasppp... speculative... speculative.....  groupbuy = gambling
