Author Topic: PSU Fan  (Read 2215 times)
PSU Fan
« on: Sun, 08 May 2022, 08:06:56 »
Every year it does that click click click thing because it needs lube.
But Tp4 is 2 cheap 2 replace the fan entirely because it still works, and relubes every year, used for 5 years, relubed once a year for 8 years in a row...
Why don't they make this easier, and we go back to Oil_Ports
Offline Leslieann
Re: PSU Fan
« Reply #1 on: Sun, 08 May 2022, 11:01:46 »
Don't mess with power supplies, they will destroy your entire system.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: PSU Fan
« Reply #2 on: Mon, 09 May 2022, 02:28:02 »
I've a bad habit of banging my pc like The Fonz bangs a jukebox to stop the rattling. idk what the rattling's from, but it's persistent and the only solution seems to be a forceful hammerblow to the side of my case. Works 70% of the time, every time.
fan? hd? gpu? who knows!
Re: PSU Fan
« Reply #3 on: Mon, 09 May 2022, 07:32:43 »
prolly screws/cable rattle.
