Author Topic: pcbuild: my plans  (Read 9544 times)
Offline PlayBox
pcbuild: my plans
« on: Tue, 05 July 2022, 13:49:30 »
i live in poland and i have a budget of 3500pln for a pc including a monitor
ryzen 5 3600 )
asrock fatal1ty b450 gaming k4 ) bundle 750pln
silentiumpc fera 3 120mm )
patriot p300 500gb 200pln/kioxia exceria g2 1tb 350pln
corsair rm550x 550w 300-350pln
silentiumpc ventum vt2 tg + 3x fans (same as in case) 250pln
rtx 2060 6gb ~1100pln
24" 1080p 75hz monitor 550pln
and if budget allpws it ill get akko pc75b plus for 550pln
price overall: 3300pln there is also a 150pln build fee included in the 3500pln budget because i cant build it. what do you think. i would normally ask on discord/reddit or ltt forums but im insane and i use amazon kindle
propably sent from my amazon kindle 10th gen
Re: pcbuild: my plans
« Reply #1 on: Tue, 05 July 2022, 15:27:14 »
You'll get much better performance per dollar build at 6000kln.
Tp4 recommends saving up instead of buying now.
Offline PlayBox
« Reply #2 on: Tue, 05 July 2022, 15:35:21 »
i dont need much more and it will take ages for me to save up. thanks for reply
Offline Leslieann
« Reply #3 on: Tue, 05 July 2022, 18:15:37 »
You forgot ram.
If you plan on upgrading to RTX 3000 or 4000 (or AMD equivalent) or plan on a better PSU, while perfectly fine for what you plan to use it for, a higher CPU load (Intel) will push it to where it gets loud and the GPU transient loads will cause system crashes. Again, perfectly fine for this build, just keep in mind it won't be enough for much more.
Same applies to CPU cooler, it's fine for that GPU but if you get anything much more power hungry it could be an issue.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #4 on: Tue, 05 July 2022, 19:59:38 »
yes but you will have a computer ~3x - 3.5x the power at less than 2x the cost.
Offline Darthbaggins
  • PC Cannibal
« Reply #5 on: Wed, 06 July 2022, 10:55:43 »
ryzen 5 3600 )
I would add in a set of 16GB DDR4 3600/3200 CL14 to 16 on a kit - there have been amazing deals floating around for DDR4.  I picked up a 16GB 3600 kit for my son's build for $48 USD/226 PLN thanks to a flash sale - there are quite a few good kits in the sub $50 USD range for 16GB (2x8GB) 3200-3600Mhz.
Also like a few have mentioned, I would look more at getting a good 650w PSU (Seasonic, SuperFlower, EVGA Gold Series, Corsair RM Series)  - good 80+ Gold series can also be found for a good price as there have been alot of sales going on and GPU prices are plummeting at the moment
« Last Edit: Wed, 06 July 2022, 10:57:52 by Darthbaggins »
Offline Leslieann
« Reply #6 on: Wed, 06 July 2022, 11:01:42 »
yes but you will have a computer ~3x - 3.5x the power at less than 2x the cost. [/size][/color]
Sorry but telling someone on a budget to save twice as much is unreasonable.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline PlayBox
« Reply #7 on: Wed, 06 July 2022, 12:59:34 »
ryzen 5 3600 )
oh i really did forgt the ram im planning to get ddr4 3600mt/s cl18 (yes i used the mt/s on purpose) for around 300pln i also got the cooler master c550 v2 psu its gold tier A single rail psu in psu tierlist for 250pln
