Author Topic: Tn Panels  (Read 2695 times)
Tn Panels
« on: Fri, 29 July 2022, 23:47:57 »
Plugged in an ol' TN from the basement today.
LG,  L203wt. 20inch,  1680x1050, 16:10,  60hz
Original spec:  300 nits, CCFL
What's left: 130nits,   This only ran ~13,000 hours.  so much for LG quality...
540:1 Contrast ratio left. the reason is the blue channel is weaker now due to the wear/tear.  it should be around 700-800:1 brand new.
Gamut is pretty good, 92% srgb (103% volume)
People knocked TN for bad color, but this wasn't always true.
Takes Tp4 right back to early 2000s Gotta tilt your head JUST RIGHT, otherwise the contrast is messed up.
When you get the eyes lined up though, still looks pretty good.
Offline Leslieann
Re: Tn Panels
« Reply #1 on: Sat, 30 July 2022, 00:14:18 »
LG is an OEM, but LG consumer products are known to use parts from any supplier, not just LG, especially at the lower end.
So while it's an LG monitor it doesn't mean the panel inside is LG.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Tn Panels
« Reply #2 on: Sat, 30 July 2022, 01:00:23 »
Hrrrrm....in the service menu this model uses a taiwanese panel by CPT,   they would've been at technological parity with what LG was doing around this period though.
Offline Leslieann
Re: Tn Panels
« Reply #3 on: Sat, 30 July 2022, 01:51:10 »
Just saying don't blame it all on LG.
It may not be even close to parity, it may have been he only way to reach that price point.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Re: Tn Panels
« Reply #4 on: Sat, 30 July 2022, 08:09:18 »
but i do blame LG, they chose this panel. it sux0rz. lg's dithering chip at this stage was also crummy, gradients are not smoot
Re: Tn Panels
« Reply #5 on: Sat, 30 July 2022, 20:48:06 »
Watching resident evil on it, the n00 tv show.
Honestly, it looks pretty good, much better than I remembered back in the day.
with 1080p media,  high quality image scalers,  end to end color calibration/correction, these old panels are no slouch, used properly, they look great.
Re: Tn Panels
« Reply #6 on: Sat, 30 July 2022, 22:10:31 »
Why people downvotn' this show,
not great, but not awful at all.
