Author Topic: pic0 de gall0  (Read 2727 times)
pic0 de gall0
« on: Mon, 01 August 2022, 09:48:02 »
Problem is the raw onion,   it's just tooooo onion-y ?
thoughts ?  cook the onion ?
Re: pic0 de gall0
« Reply #1 on: Mon, 01 August 2022, 10:15:02 »
A quick spin through the microwave, say about 30 seconds as a start, goes a long way towards taming the harshness of raw onion.
You can go much longer and eventually even brown onion in the microwave if you need to.
- D Trump 2026-10-24
Re: pic0 de gall0
« Reply #2 on: Mon, 01 August 2022, 14:12:06 »
Try different types of onions?
Re: pic0 de gall0
« Reply #3 on: Mon, 01 August 2022, 14:41:33 »
which onions do you guys recommend.
specific concern is the stinging raw onion-i-ness thats a bit overpowering
Re: pic0 de gall0
« Reply #4 on: Mon, 01 August 2022, 15:08:27 »
I use yellow onions for almost everything, and sweet onions (subset of yellow) when they are available and reasonably priced.
Re: pic0 de gall0
« Reply #5 on: Mon, 01 August 2022, 16:08:19 »
If red is too strong, use yellow sweet like Vidalia or Walla Walla. The best for caramelizing.
Re: pic0 de gall0
« Reply #6 on: Mon, 01 August 2022, 20:32:09 »
Red onion are my fav for raw BUT they can sometimes be too hot. My current batch is mild and so good!
