Author Topic: Reformatted an old hard drive that had Windows installed... Still tries to boot  (Read 3048 times)
Offline Naweo
I think bios is trying to boot into an old hard drive. I have installed windows on a new SSD and simply want the old SSD for stoage, and so I wipled it clean with a reformat. It appears there is still an un-deletable bootable partition, and I can't seem to remove that boot partition.
Any ideas?
Thanks
https://i.gyazo.com/b77a8561bccc32a8e12b0ed502509af0.png
Not sure that I'm remembering correctly, but can you right click on the partition and do a "delete partition"?
- D Trump 2026-10-24
Offline Leslieann
First off, remove the drive you want to format... Boot up the system, that should get the bios to correct, but also it will ensure your system is not booting off of that drive.
It's very possible it's using the boot partition on the to be formatted drive  to boot your SSD, which is why you can't format it.
If that's the case when you remove it your system will not boot, you can either fix it with a Windows disk or put the other back in and ignore the problem.
If it boots with the one removed (or after you have fixed it), reconnect the drive to be formatted. Note that if it's a relatively new system you don't even have to shut down to reconnect it. However, instead of formatting it, delete all of the partitions on it, then create a new "simple" partition and format that. That will get rid of any boot sectors and give you max capacity.
Fair warning,
It's very likely you're using it to boot your SSD.
« Last Edit: Thu, 25 August 2022, 23:04:51 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Naweo
Yes I made a few threads about this. I will come back after I have booted one the drive I intend to use only and removed the drive I intend to format / remove as a bootable drive.
If windows boots normally WITHOUT the annoying hard drive inside, then I can safely attempt to remove the bootable partition, correct?
Offline Naweo
Fair warning,
I can now confirm the drive in question (crucial SSD, no other crucial drive in the system) is unplugged, and the PC boots fairly.
I can now safely attempt to remove the bootable partition, correct?
Offline Naweo
Fair warning,
I believe it was a success. The crucial disk is now fully a single volume:
https://i.gyazo.com/ebc6f294814d7c6c9786a6389b0be073.png
Offline Leslieann
Yep, looks good.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Naweo
Thanks a lot. Appreciate it.
