Author Topic: ball bearings.  (Read 2118 times)
ball bearings.
« on: Tue, 13 September 2022, 08:35:16 »
are you not suppose to oil ball bearings ?
Everytime Tp4 does it, they start to make this tongue clicking noise, like grrrrrrr.... tshch..tshch...
how do get into the tiny sealed fan bearings without breaking the metal cover ? it's not the rubber covers which goes back easy.   This is why tp used the oil in the first place, can't get those covers off without breaking them,  is it supposed to be grease only ?
Offline Darthbaggins
  • PC Cannibal
Re: ball bearings.
« Reply #1 on: Tue, 13 September 2022, 10:13:22 »
normally ball bearings use a grease to lube them over time.
Offline Leslieann
Re: ball bearings.
« Reply #2 on: Tue, 13 September 2022, 13:40:31 »
Depends on intended use but almost all use grease.
The metal shields are usually either press fit or c-clip and won't come off without damage.
Most (if shielded) are considered expendable and not intended for rebuild and if it runs rough, regardless of lube, it's toast.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
