Author Topic: Unable to boot  (Read 34939 times)
Offline ivanlovric27121991
    • balqalal
Unable to boot
« on: Sun, 19 March 2023, 03:23:55 »
Hey there ! I have a problem I think you can help me with. I have a Toshiba satellite a300 1G5 and I installed ssd in it. After that  my usb stick is unrecognized in the bios and I can't boot from it to install windows from it. And I marked it as active using diskpart and still nothing.
The error message is "active partitions not found . Press any key "
Thanks.
Poslano sa mog 220733SG koristeći Tapatalk
Re: Unable to boot
« Reply #1 on: Sun, 19 March 2023, 08:52:45 »
My first guess would be a faulty USB drive.
Can you check it in another computer?
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
    • balqalal
Re: Unable to boot
« Reply #2 on: Sun, 19 March 2023, 08:54:27 »
No the stick works fine on the other machine. It boots and everything, dunno
    • balqalal
Re: Unable to boot
« Reply #3 on: Sun, 19 March 2023, 08:56:42 »
This thing happens every time I install SSD into it. When I remove the SSD and put the HDD back everything is normal and the USB boots.
Offline Leslieann
Re: Unable to boot
« Reply #4 on: Sun, 19 March 2023, 14:00:26 »
I have one laptop where it will ONLY boot the USB from a cold boot.
If you reboot, no matter what, it will not allow you to boot from any external device. You have no idea how long it took me to figure that one out.
Another problem could be the formatting and how Bios handles it. The bios may be switching to UEFI/GPT/secure boot once it sees a properly formatted drive (i.e. the ssd). Look in the bios and see if there's an option to allow MBR or legacy boot. This option may only show up if secure boot is disabled as secure boot requires GPT formatting.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Unable to boot
« Reply #5 on: Mon, 20 March 2023, 06:34:14 »
bios has alot of hidden settings they lock away from us.
Offline Darthbaggins
  • PC Cannibal
Re: Unable to boot
« Reply #6 on: Mon, 27 March 2023, 06:26:57 »
In some cases it's good to hide those settings away, I have seen people mess up things to cause boot/post issues.
I can bet they dont have the Boot from external media/USB setting enabled - alot of machines have this disabled by default.  Normally this setting is in the boot/system menu in the bios.
