Author Topic: |)ata(enter n0ise..  (Read 3789 times)
|)ata(enter n0ise..
« on: Fri, 28 April 2023, 09:45:31 »
Thoughts?
Persistent droning ?  Harmful ? Stress ? Anxiety ?
Offline Sniping
Re: |)ata(enter n0ise..
« Reply #1 on: Fri, 28 April 2023, 16:58:50 »
not a datacenter but my work computer gets pretty loud a lot of the time. it'd say it's mildly anxiety inducing. when i built my first computer as a teen I didn't care about the amount of noise it made, even though desktop pc fans usually don't sound as irritating as laptop fans, I'm a fan of quiet computing these days.
Offline Leslieann
« Reply #2 on: Fri, 28 April 2023, 23:08:00 »
All of the above.
And I'm pretty sure long term it can cause problems... I don't deal with that sort of noise well since working on aircraft.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #3 on: Sat, 29 April 2023, 07:31:19 »
All of the above.
is this why LLann only uses the most expensive computer fans ?
Offline Leslieann
« Reply #4 on: Sat, 29 April 2023, 15:40:39 »
It's not like I have a bunch of Noctuas (haha), I use good parts, bang for the buck parts and research, but yeah I hate the noise and put a lot of effort into making sure my systems are quiet.
Once I rebuild my cnc rig I hope to make some water blocks and plan to pump all the heat and noise outside.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
