Author Topic: Those $50 1080p projectors  (Read 3392 times)
« on: Sat, 22 July 2023, 06:18:10 »
NE1 have one?
Spec seems ~60% srgb, ~200:1 contrast, usable.
But it's a projector, and it does projector stuff.
Tp4 thinking about getting one.
Offline Leslieann
Re: Those $50 1080p projectors
« Reply #1 on: Sat, 22 July 2023, 09:12:58 »
Look into the lifespan before you buy.
Many have an expensive bulb that lasts a very short time, if you can replace it at all. Others can overheat really fast or have a very short battery life...
They're cheap for a reason.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Sat, 22 July 2023, 09:35:49 »
add cooling fan + heatsinks to lamp ?
Offline Leslieann
« Reply #3 on: Sun, 23 July 2023, 20:37:56 »
Nope.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
