Author Topic: It's come to this...  (Read 4661 times)
« on: Mon, 07 August 2023, 10:09:50 »
They've cheaped out on the tooth paste tube.
It used to have the shape-holding aluminum liner, now it's just white plastic tube.
301320-0
Re: It's come to this...
« Reply #1 on: Mon, 07 August 2023, 10:21:12 »
They have been like that over here for decades.
I'm guessing that it is just because they are easier to recycle.
« Reply #2 on: Mon, 07 August 2023, 12:43:51 »
Really? I guess America just had a higher standard of toothpaste ergonomics. /jokes.
Offline CaesarAZealad
  • Racc
« Reply #3 on: Tue, 08 August 2023, 16:03:11 »
TP4 why were you cutting up your toothpaste tubes?
How did you know there was an aluminum liner?
How did you know without cutting it open that something was different? or do you just cut open all your toothpaste tubes?
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
« Reply #4 on: Tue, 08 August 2023, 16:12:45 »
/// Secrets ///
No, but cuz Tp4's p00rt1tude is truly @ 150%, he must recover all the paste that's still in the tube after he gets to the end. There's usually a good 10 days worth of brushing left in the tube, if you routinely use ~pea-sized amount each session.
« Reply #5 on: Tue, 08 August 2023, 18:02:26 »
Tp4's p00rt1tude
This from the guy who once referred to a $1500 call girl as "mid-grade" ....
- D Trump 2026-10-24
« Reply #6 on: Tue, 08 August 2023, 18:58:09 »
Tp4's p00rt1tude
That comment is relative to reference costs, not Tp4's expense capacity.
